Old 12-05-2010, 01:40 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
vortec 4.3 starter on my 72 350
I was at a local engine rebuild shop picking up a buddies rebuilt 350 and when I went to start my truck, It took a while to start (heat soak in the starter). An engine builder came out and we discussed the problem. He said that he uses a smaller starter from a 4.3 mid-size blazer. He said that it cured all of his hard start problems with his 69 427 camaro. What do you guys think about the swap? Do you think that it would have the same terminals as my current starter (direct swap)?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 12-05-2010, 06:13 PM   #2
Danomt
Danomt's Avatar
Re: vortec 4.3 starter on my 72 350
Not enough info. Chevy has two different flywheels, 153 and 168 tooth. Either can be on either of the engines you are comparing. The inline starter bolts are for the 153 and the offset are for the 168. Then there are exceptions to these. We have replaced a lot of the old big starters with the newer gear drive small ones and they are great. Different year blazers even have different starters listed. More info and I can help ya. DanO
1972 c10 SB
1968 c10 SB
1970 c10 LB
1971 k10 LB
1970 k10 LB
1972 gmc 2w LB
Some projects, some should be.
Danomt is offline   Reply With Quote
Old 12-05-2010, 06:54 PM   #3
hugger6933
It will work. I have put 4.3 starters on a v-8 motor before. Jim
hugger6933 is offline   Reply With Quote
Old 12-05-2010, 06:56 PM   #4
hugger6933
It will work fine. I have put 4.3 starters on a v-8 motor before. Jim
