Too old for sythentecic oil?
I had the oil changed in my 72 today. I was planning to go with Valvoline Synthetic, but the manager told me it was "too old for sythetic." I didn't push the issue as I have no issue with conventional Valvoline but afterward I got to wondering if I'm missing something. I understood that the sythentics were fine for older engines.
Any thoughts?
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
Re: Too old for sythentecic oil?
It was explained to me that synthetics have a lower zinc content which make then a bad choice for older non roller motors. If you decide to run synthetic it's best to add a zinc additive.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
#3 | |
Mobile 1 has a whole site dedicated to these myths. But it all boils down to, All vehicle benefit from using synthetics, Not to say there is anything wrong with traditional oils. Just that synthetics last longer, And keep your engine cleaner. If you think you have a lot of sludge in your motor, I would change it a little sooner after switching over, The first time ( it will clean your motor). Then use recommended times. Spike ![]()
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
#4 | |
The Older Generation
its all about the +6 inches
there's a few reasons not to run synthetic... but no real good reasons. (other than burning and leaking oil as mentioned)
The zink comment above holds no water, becouse there are no 'over the counter" oils on the market (including rotella) that contain enough for non roller motors. |
"brand new second-hand"
Well-do you guys add a zinc additive to your fresh oil change? If you do, what do you use? I use Valvoline and I thought it had all I needed, but I wouldn't hesitate to add a zink additive if it will help. I read recently that oil is going to change in ratings soon so that it's compatible with the newer engines? any thoughts?
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
#8 | |
One very good reason for not running full synthetic oil in an older engine is that they clean your engine. Now I know that sounds crazy but when they clean an older engine it breaks loose years of metal particles and other particles that your filter cannot trap. And if your running a cellulose(paper) filter it ges even worse, I saw a study that showed that if you run an AC or FRAM or basically any non-synthetic filter you might as well not be running one at all, they cannot trap particles smaller than 20 microns. So I run Valvoline(non-synthetic) and a Mobil 1 synthetic filter.
#10 | |
I shoulda worded that properly I guess. |
Check this out, thats what im putting in my truck.
http://www.amsoil.com/storefront/amo.aspx
1969 Chevy c20(Miss Hackjob) |
#12 | |
I'm running a crate motor in my truck. The manufacturer clearly states DO NOT run synthetic oil unless you add a zinc additive. I would say the zinc argument does hold water.
#13 |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#14 |
the absence of ZDDP (zinc) in motor oils is irrelevant to the performance rating of an engine.
#15 |
valvoline vr1 20w50 is still high zink till the end of next year
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 ![]() ![]() |
#16 | |
It'll Buff Out!
![]() Join Date: Apr 2007
There lowering the zinc? Damn EPA I bet
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
#17 |
they better not... thats what i run grrrr
#18 |
Simple? What's simple?
I ran synthetic for a bit, but my truck burns so much oil I couldn't afford it so I switched back to convetional.
As to the ZDDP (zinc) debate, I did a LOT of research into this, and what I came up with is that the current synthetic oils (Mobil1, etc) have the same level of ZDDP as the oils that it was originally in back in the early 60's. The problems with non-roller motors only developed in the late 60's when they started building factory motors with radical cams and stronger springs. Simply put, a factory truck motor with a mild cam and non-performance springs could run on the original ZDDP levels, which are THE SAME as the current levels in synthetic oils. Once I replace my rings and valve seals so it stops burning, my truck is getting Mobil 1. 2cents
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
#19 |
Moderator
![]() Join Date: May 2007
I have used Mobil 1 for years in all of my vehicles. My 402 has always had a sticky lifter, that eventually kept tapping non-stop. I added Hyper Lube (ZDDP additive) to my crankcase and the lifter noise went away within 5 mins and has NOT returned since. Made a believer out of me, I ALWAYS use it when changing my oil now.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#20 | |
Zinc and Phosphorus Enhanced ZDDP Formula Ideal for High-Performance and Classic Car Engines I forgot to list what type of oil...
#21 |
It'll Buff Out!
Ahh The great oil debate, well here are my 2 cents to add.
First let’s look at Synthetic vs. Dino oil. Synthetic oil is artificially synthesized. Think of it on a molecular level like this. You take a work bench and dump a bag of dimes out, all the dimes are the same size, even and uniformed (I’m not using a micrometer for this debate) They transfer heat better do to this and provide uniformed lubrication. Now let’s look at Dino oil or Conventional, Add quarters, pennies, half dollars, dollars, those gold dollars, etc. Now we have oil on a molecular level that even after refined has a whole bunch of different sizes. What this does is transfer heat less efficient and the larger molecules will clump together and allow less seepage / leaking because it provides less gaps for the smaller molecules to pass by. How I experienced this first hand, I changed the rear end oil in my 72 and went to a full synthetic, two days later the axel seals were leaking. I drained the oil, refilled with conventional and the leaking stopped. I was able to go almost another 2 years before they started leaking and needed to be replaced. The saying goes if it leaks with synthetic, if will eventually leak with conventional. So if you already have an oil burning, seeping, leaking machine. It is not recommended to switch. As far as the Zinc debate goes. Zinc has been drastically cut down or almost eliminated from today’s conventional oils due to catalytic converter failure. I would like to know what the conventional oil of the 60’s levels was. For this I have researched and can’t seem to find the Data any more the Hearsay. Here are some examples of what I have found about Zinc in some of the oils out there. Rotella T-1 Currently 700 ppm (parts per million) Per Shell it was recently reformulated, It used to be 1200 ppm. Castrol won’t release the information on its GTX or GTX High mileage for proprietary reasons except to say it has lower quantities of zinc. They will say their syntec 20w-50 is 1200 ppm and is recommended for flat tappet cams Mobil 1 10w 30 has a rate of 800 ppm and this oil is used in many cars with catalytic converters with no problem. Mobil 15-50 has 1200 ppm; this oil seems to be recommended on a lot of exotic sports cars Valvoline VR1 Racing oil is the highest off the shelf oil I have found and at 1400 ppm it is not recommended for use in vehicles with catalytic converters. I will add that the Lucas oil engine break in additive when mixed with 4.5 quarts (per manufacture) will give you 5000 ppm zinc. This still doesn’t end the debate on which oil is better. Everyone will make their choice for their own reasons I just wanted to add what I have found out over the years and am sure will continue to learn as this is debated probably way past my lifetime.
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB Last edited by So.Cal.Super; 12-06-2010 at 02:30 PM. Reason: grammer |
#22 |
upgrading to an older model
I drive a dirt track car (olds 350 +.040). It does have a tendency to run hot (250-270). I have tried a number of diferent oils. VR1 breaks down VERY quickly 2-3 weeks is about all you can get then the oil pressure drops, Regular Royal Purple is a little better, but the best that I can find is Royal Purple XPR...does it have zinc? don't know haven't looked but I do know I changed oil in the racecar in May and I was still maintaining 50psi of oil pressure at the end of the season (Oct).
68 stepside, short-box, multi-colored (for now) ![]() ![]() ![]() |
#23 | ||
Salient point, and the source of my belief that synthetics are fine, are in bold. 0.08% (800ppm) was enough to solve the wear issues that they found in high lift flat tappet cams, and non-performance engines were okay at 300ppm. Since Mobil1 is 800ppm ZDDP, I will continue to run it in all my engines. In the end, it's just personal preference. I like synthetics because they wear better and have superior performance characteristics over a wider range of temperatures - they also don't generate sludge or break down under heat like dino oil does. Quote:
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) Last edited by JJorgensen52; 12-06-2010 at 04:30 PM. |
#24 |
It'll Buff Out!
Brock, with temps like that conventional oil will always breakdown faster. And that is some serious engine temp. Royal purples website talks about enough ZDDP to work with flat tappet or roller valve trains glad to see you are having good luck with it.
JJ Thanks for the read, I've always loved the oil Debate and that is some good reading. Personally I will stick with my VR-1 and good filter (Napa gold or Wix) (not trying to start the filter debate) and I like using a bottle of Lucas oil stabilizer, I change it every 3k and the oil looks and smells great. And I run around at 80mph on the freeways here. Like I said we will all have our preferences and that’s what makes this always a good read.
#25 |
I agree...
