Old 12-05-2010, 05:36 PM   #1
brans72
Headers in 67 C10 ?
Ok guys We have a 67 C10 with 350 engine and 700R4 transmission,also Front crossmember is from a 83 truck. All that is installed no biggie right well I am curious befor I start going to deep if the Headers I got with the engine (79 C10 truck) will work in my 67 C10? I tried for few mins with now luck thought about pulling transmission out since still building truck. So will headers from a 79 C10 work on 67 C10 if I got a 83 crossmember? Thanks in advnce guys!!!!
brans72 is offline   Reply With Quote
Old 12-05-2010, 06:57 PM   #2
69 longhorn
Re: Headers in 67 C10 ?
I had a set of 69090 Hedmans(orig purchased for a 78 C-20),& also ran them on my 69....so yes , they should fit The top lip on the frame rails are a little wider on the 67 frame in the eng compartment(due to the BB added to the 68 line), but I think the headers will clear. They need to go in from the bottom. crazyAl
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 12-05-2010, 08:12 PM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I have some cheapo flow tech longtubes on mine and they say they fit anything from 67-87ish, they have enough room that last time I pulled the engine I left them on the engine and it came out with no problem. You should have no problems except for the frame rails being a little tighter, you may have to do some trimming.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-05-2010, 10:35 PM   #4
jablack
Classic Chevy Recycler
jablack's Avatar
I had problems on my 67 when I used the original V-8 engine stands. When I used the inline 6 stands they fit just fine, except for the back flange bolt on number 8 cylinder was hard to tighten.
I'd like to find some that would fit good with the V-8 in the original position.
2004 Chevrolet Trailblazer EXT
1970 Chevrolet C50
1979 Chevrolet C30
Need another 67 or 68 soon...
jablack is offline   Reply With Quote
