Okay so i ordered left and right outside mirrors for my 1972 cheyenne from Classic Parts of America as seen here http://www.classicparts.com/1970-72-...ctinfo/58-121/http://www.classicparts.com/1970-72-...ctinfo/58-122/ i got them and installed them and the left mirror works perfectly i can see the side of my truck but on the right one i can't and i moved it as much possible any help with these mirrors? here are some pictures i took. Left Side Images
Active Member
![]() Join Date: Jul 2007
Re: Sideview mirrors help!
Hard to get a good look at the mirrors. Try posting the pics again but use this method:
(Print and follow step by step) 1. After you click on create (or reply) a post, click on small paper clip above or scroll down and click on "Manage Attatchments". 2. The "Manage Attachment" window pops up (Notice at the bottom you're only allowed 100KB per picture.) Click on one of the "Browse" blocks. 4. The "Choose file" window pops up. If your folder is there, expand it. Otherwise, click on down arrow to look for your folder. I keep all my truck related pictures in a separate folder. 6. In a blank area of the open folder, right mouse click so you can choose "View Thumbnails." For Windows 7 click on "large icons." 7. Right mouse click on your pic and choose "Properties." Make sure it's less than 100KB. (see #8) 8. If it's larger you can resize them. Right mouse click the picture and hopefully you will have a "Resize Pictures" selection in the pop-up window if you don’t, google resizing pictures and download a resizing programs from several sites. (sometimes the forum program will resize them for you if it’s not too large) 9. If you have the microsoft resizer, select "Resize Picture" and choose "small". It's always worked for me on that one. 10. A smaller pic will be created in the same folder. Choose it and it should appear in the "File Name" window. 11. Click "Open" and the "Manage Attachment" window pops up again. 12. Click "Upload." 13. Click on "Close the window" or you can minize it if you want. 14. To view before submitting, click on "Preview Post." Last edited by 68gmsee; 12-05-2010 at 09:52 PM. |
K i will repost this 2morrow thanks.
![]() Join Date: Oct 2007
Did you install the passenger side mirror further towards the rear of the truck than the one on the drivers side by about 2 inches or so? That enables you to see past the wing window post from the the drivers seat..
I forgot how many inches ,,maybe 2" this is factory settings.. gp Larry Last edited by GOPAPA; 12-05-2010 at 10:59 PM. |
@GOPAPA Ijust installed the mirrors where the old ones were ! i will try to see further 2morrow, do you have any pictures you can show me of how they should look on both sides?
The picture is the factory RH sport mirror placement as located on my 72 C10 measured from the front edge of the door. The penciled line is one inch below the door body line. Looks like the drivers side is 1.3 inches further forward, per the assy manual. Hope this helps. found this in seach gp Larry
@GOPAPA Thank you for the picture, i will try this tomorrow when i get out of school !
Grandpa in the rustmobile...
i ordered some like that (sorta) from them and the chrome/stainless is already starting little rust spots!!!
Look good man! What did ya have before?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Tags |
sidemirrors 1972 pickup |
