Old 12-05-2010, 09:12 PM   #1
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
3970024
got this engine out of a running truck ,runs good .i think i'll put new stock cam ,hv oil pump ,350 heads and 4bl carb intake . question is i think it has what they call 202 heads and they don't have holes drilled for a/c comp etc. .guys what heads and intake should i look for .o yeah it's a 307 engine .
1964 CHEVY 1/2 C/10 FLEET
1981 CHEVY 1/2 C/10 FLEET
1995 DODGE 1500 V6 FLEET
EAST
http://www.flickr.com/photos/bigasspimp/?saved=1
BIGPIMP is offline   Reply With Quote
Old 12-05-2010, 09:17 PM   #2
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
Re: 3970024
i'm looking for the intake with the oil filler tube coming thru the intake .what year was that ?
EAST
Old 12-06-2010, 12:11 AM   #3
bama63
bama63's Avatar
Re: 3970024
due to the small bore (3-7/8) i would go with a set of 305 heads to keep the compression up and if you look for a set of HO heads they can be had with large valves and improved ports and as far as the intake goes look for an old torker-2 or 69 or older gm intake hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 12-06-2010, 12:26 AM   #4
bama63
bama63's Avatar
Re: 3970024
try here http://www.thedirtforum.com/castings.htm if its the same engine as in your flicker folder it is a 3970014 which is a 68 - 79 350 200-255 2&4-Bolt main and the heads are positively double hump heads by the pics and are most likely cast number 3890462 62-68 1.94/1.50 & 2.02/1.6 250-350 64 CC Chambers No bolt holes, double humps hope this helps
Old 12-06-2010, 12:48 AM   #5
Captainfab
60-66 Nut
Re: 3970024
I agree
Those heads were available with either 2.02 or 1.94 intake valves. More that likely those have 1.94 intake valves. There are better heads than those, but it depends on what you expect from this engine and what your budget is. If it runs as it is, I would just leave the heads on there.
Old 12-06-2010, 06:32 AM   #6
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
Re: 3970024
it's a diff engine than in my sig
EAST
Old 12-08-2010, 03:14 AM   #7
raycow
Re: 3970024
I believe the last year for the oil fill pipe was 67 or 68. Any intake older than that should have it. The manifold on my 60 has the pipe.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-08-2010, 04:18 PM   #8
mikie 1954
Re: 3970024
If you look in summit racing and jegs catalog they have edelbrock manifolds with the oil fill tubes,may be others available.
mikie 1954 is offline   Reply With Quote
