Old 03-06-2003, 01:33 AM   #1
rayville body
header idea
i dont know about you guys but i dont like the way headers on our trucks hang low. i was just thinking abuot different options. 82-92 camaro headers should fit. the 81-87 truck manifolds are the same as the 82-92 camaro low performance manifolds,aernt they? just a thought. anybody else got a good idea or tried somthing of this nature before?
rayville body is offline   Reply With Quote
Old 03-06-2003, 02:05 AM   #2
82BlackBeast
I used some made for a '69 Camaro, but it took some mods to get them in there. They tuck up in the truck real nicely though. I had to modify the motor mount clam shell on the driver's side, build a crossmember and shift linkage, and had to notch the frame on both sides of the motor. Like I said, it took some work but I think it was worth it in the end. Here's a pic....pic
Matt
My Site
82BlackBeast is offline   Reply With Quote
Old 03-06-2003, 03:31 AM   #3
1FaastC10
1FaastC10's Avatar
Matt, what brand are those headers? and what is the primary tube size? maybe even a part number?
1FaastC10 is offline   Reply With Quote
Old 03-06-2003, 03:39 AM   #4
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Jeremy here's some info on the truck that has the header info on it. http://www.morgan.net/~mscibek/mods.htm
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-06-2003, 08:59 AM   #5
AirMale
AirMale's Avatar
I think some guys are using 67-74 Chevelle shorty headers from Dynomax. I am lowering my truck to 4/6 and will need new headers as well. I will probably order the Hedman Elite shortys for Chevelle for a couple of reasons. 1. Flanges are 3/8 and I never had a problem with my current ones as far as leaks.
2. The 14 guage tubing keeps the noise down better than thinner wall tubes.
3. The primary tubes are 1 5/8 vs. 1 1/2 tubes on the Dynomax.
The negative is that the Dynonax ceramic headers look much better and come with a lifetime warranty. Do your homework
I hope to be converting to a big-block this summer and was told that the full length Chevelle big-block headers work with a double hump crossmember.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 03-06-2003, 10:08 AM   #6
82BlackBeast
Thanks for putting up that link B!!
1Faast - They are Hedman Hustlers that are ceramic coated. I can get you a part # if you want, I have the receipt around here somewhere.
Matt
Old 03-06-2003, 10:37 AM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Typically the Chevelle headers will work. You can also use the 88-99 pickup headers. A friend used a set of those.
As for full length Chevelle BBC headers, I can tell you that my buddies WON'T go in a pickup without some MAJOR modification to the truck, so check an double check depending on what kind you have.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-06-2003, 11:33 AM   #8
1FaastC10
1FaastC10's Avatar
Matt
that would be sweet. im getting ready to do a 5/7 drop, and dont want any ground clearance problems. i was going to go with shorties, but i'd like the performance of a full length better.
Old 03-06-2003, 11:39 AM   #9
BigRed
I'm sure he will chime in, but low84 has shortie headers on his truck. I'm pretty sure the are chevelle headers and he didn't have to do any notching to get his in.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 03-06-2003, 11:48 AM   #10
1FaastC10
1FaastC10's Avatar
they're also 1 5/8" primaries, i'd like to find 1 3/4"
Old 03-06-2003, 01:07 PM   #11
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Or you could save your self all that trouble and spend more and get some JBA shorties made for our trucks...no trimming..no notching and no fabricating. hehe
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 03-06-2003, 01:51 PM   #12
1FaastC10
1FaastC10's Avatar
not all of us are made of money Dave. i could build a shortblock with what you spent on those headers.
Old 03-06-2003, 02:07 PM   #13
LOHRTBT
LOHRTBT's Avatar
lmao!! Well I am hardly made of money...lol But yeah they did cost a lot...but you know..I am very satisfied with them and seriously doubt they will ever need replaced. No leaks still and not tightened once in 1.5 years.
~Dave~
Old 03-06-2003, 02:17 PM   #14
ocbaud
Garage Queen Material
i'm getting the dynomax shorties when i replace my headers
ocbaud is offline   Reply With Quote
Old 03-06-2003, 03:49 PM   #15
low 84
low 84's Avatar
i do have the dynomax chevelle shorties and they fit and work great. when you go over 400 hp though you will really benifit from a full length. after i drop the new motor in this summer i am going to consider what matt did, with the custom tranny crossmember and camaro full lengths, but he tells me its not too fun
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-06-2003, 09:47 PM   #16
82BlackBeast
Ok, I finally found the blasted receipt for those suckers....the part # at Summit is HED-65003. Also, they are 1 3/4" primaries, I forgot to answer that question before, sorry about that 1Faast. With the shorties that everyone is talking about you shouldn't have to do any mods to the truck to get them to fit, but these are full length and don't hang down below the frame, that's why all the fabrication and "notching" had to be done. Getting some that didn't hang down was what I wanted and these fit nicely as far as that goes. I have about a 6/8 drop and most other full headers would be sitting on the ground. The only real pain was making the crossmember and making sure the tranny mounts at the right angle. But I like the performance of the full length and with my setup I felt they were needed and worth the work. I guess it all just depends on what you want and what you feel should be put in there.
Ryan, let me know when you ready to put some in, I'll head that way and see if I can't give you a hand. I can bring the truck down there so we have something to go off of...
Take care,
Matt
Old 03-07-2003, 03:07 AM   #17
1FaastC10
1FaastC10's Avatar
wow, that does look like a lot of work. but, well worth it in the long run.
Old 08-20-2003, 09:32 PM   #18
kevhill85
91 SWB 383
kevhill85's Avatar
here a pic low84 headers . he has a 3650 in his truck . he just change cams
here the link to where the pic at .
http://67-72chevytrucks.com/vboard/s...threadid=59544
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040,
http://photobucket.com/albums/q169/k...ahoe prostreet
kevhill85 is offline   Reply With Quote
Old 08-21-2003, 02:46 PM   #19
loweredd
www.loweredd.com
loweredd's Avatar
so low 84, those fit with no mods at all?
loweredd is offline   Reply With Quote
Old 08-21-2003, 03:38 PM   #20
low 84
low 84's Avatar
yes they fit with no mods at all
'05 1500 Crew Cab
RIP
Old 08-21-2003, 05:17 PM   #21
loweredd
www.loweredd.com
loweredd's Avatar
right on!
Old 08-21-2003, 09:45 PM   #22
phantom dually
Project92 SWB stepside
phantom dually's Avatar
I need a full length header that will fit a SBC and NOT come below the frame rails. Also want them to be coated. No cutting the frame. JUST bolt in!! I know this a lot to ask BUT it has to be out there!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 08-24-2003, 08:44 PM   #23
1FaastC10
1FaastC10's Avatar
do yourself a favor next time, and read the whole post before you decide to chime in. that's EXACTLY what this post is about.
Old 08-24-2003, 09:45 PM   #24
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
I thought you was banned i paid you money for fender wells but you never shipped this goes back months did ya forget?? when i called and ya said you would ship either money or my wells by the end of the week did you forget that ya owed me?? THIEF THIEF THIEF dont anyone buy from this two bit piece of crap!!!!!!
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-24-2003, 09:52 PM   #25
68 Stepside
huh?
68 Stepside's Avatar
He is banned, because he is a thief. The original post is from March Bob :p
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
