12-05-2010, 09:16 PM | #1 |
Torn between 66 and 78
How did they lower my rear?
My truck is a 78 Big 10 shorty. My Uncle who owned it before me had a shop lower it and doesn't know how they did. I am not that familiar with leafs, if it was a 63-66 I wouldn't need to ask, but I need some schooling on this. It is supposed to be a 4" drop.
What ya think? |
12-05-2010, 09:21 PM | #2 |
BAD BOW-Silverado XST
Re: How did they lower my rear?
Is the front hanger reversed? You'll know because it will have bolts instead of rivets.
The leafs are below the axel. Stock, they are above the axel. Last edited by gchemist; 12-05-2010 at 09:24 PM. |
12-05-2010, 09:25 PM | #3 |
isn't that a flip kit? normally the leafs are on top of axle
12-05-2010, 09:27 PM | #4 |
the hanger in the front is still riveted to the frame.
12-05-2010, 09:27 PM | #5 |
67-72 parts collector,…
It's had a flip kit installed.
The rearend is now on top of the leaf springs. Probably a 5" or 6" rear drop. Looks fine to me,... but I'm not sure about the red rubber snubber back by the rear shackle.
12-05-2010, 09:30 PM | #6 |
12-05-2010, 09:31 PM | #7 | |
12-05-2010, 09:37 PM | #8 |
would the snubbers take some of the arch out of leafs giving it less drop?
12-05-2010, 09:39 PM | #9 |
looks like a bunch of leaf springs.i counted 8 that may be holding you up.is that part of the big 10 package.
12-05-2010, 09:43 PM | #10 |
it may be, they call it a "heavy half ton". its GVW is about 6200. How many leafs does a regular 1/2t have?
12-05-2010, 09:44 PM | #11 |
What size tires?
That is more than 4" in the rear. I'm guessing somewhere in the 5"-7" range Measure from the middle of the wheels to the top of the wheel opening front and rear. Posted via Mobile Device
CHEVY ONLY Last edited by joe231; 12-05-2010 at 09:45 PM. |
12-05-2010, 09:51 PM | #12 |
mine has 5 mines bout that low but its flipped and has 2" rear shacles.
12-05-2010, 09:52 PM | #13 |
they are 26" tall tires.
Center of the wheel to fender (wheel opening) front 14 1/4" rear 15 1/4" |
12-05-2010, 09:57 PM | #14 |
that is a 5/5 drop
http://67-72chevytrucks.com/vboard/s...16#post4331216 looks like just a flip out back
CHEVY ONLY |
12-05-2010, 10:18 PM | #15 |
yeller
Measure the leaf pack thickness at the axle, add 3" (axle tube diameter), and there is roughly your drop. You have bout a 6" drop due to the HD leafs in your truck
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
12-05-2010, 10:57 PM | #16 |
So how much lower can I go? and if I want to go lower out back I need to remove leafs and add shackles so I'm not to low, right?
12-06-2010, 12:21 AM | #17 |
At the body shop.
Any much lower and it will need a C-notch
" That didnt make it any newer " " Dont antique the equipment " |
12-06-2010, 03:28 AM | #18 |
Laid back freak
I wouldn`t go any lower then that, looks good as it is.I had a flip kit and a 2 inch bell tech hanger drop in the front and a shackle kit in the rear and it was way to low.I sold the bell tech kit and just did a flip kit and it sits level like yours and lowered.So unless you want to spend money you can do a air ride kit but thats all in your budget...
thanks pat
1980 chevy c10 step side restomod, 1970 cougar convertible 1 OF 24 ever built: 2014 Hyundai Tucson limited (daily driver). |
