Old 12-05-2010, 10:20 PM   #1
spudz
spudz's Avatar
Help with loose sm465 shifter
Got bored went out and pulled the shifter out to see if anything was wrong because it just feels VERY sloppy... First off I want everyone to know that I have NEVER been in a sm465 trans EVER. I dont know anything about them so please be gentle if I ask something stupid. As soon as I pulled the boot I started seeing stuff wrong.... Looks like one of the lock pins is gone and somone put a roll pin in its place. Then looks like someone else put a hose clamp on it to keep the pin in.. Does anyone know where I can get these pins for the case? To replace the loose roll pin. SO I pulled the shifter.. Looks like someone welded the handle to correct something? or is that factory.. Also on the lower part of the shifter, the part that goes in the end is held on by a roll pin. It fits very loose. Also the hole in the shifter itself that the pin hose through is bigger then the pin itself so this may be why its so loose. If this is the case, the shifter is garbage.. And if it is, would there be any reason why I couldnt just weld the part that fits in the end to the handle so it wont move? Atleast till I find a new shifter. With the shifter like it is and the sensitive steering its kind of a scary ride haha.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 12-06-2010, 08:22 AM   #2
tucsonjwt
Re: Help with loose sm465 shifter
My drivetrain guy told me that SM465s shifters rattle (are loose, side to side). If you weld the shifter to attempt to stiffen it, then the shifter will rattle all the time. I have a loose shifter and it makes some mechanics think it is broken. As long as the shifter works and I don't miss any gears when shifting I am satisfied. I think SM465s are very old technology, which is why enthusiasts upgrade to later model transmissions, but I have a work truck so this does not interest me. As long as I keep the clutch adjusted my old SM465 works like a dream.
tucsonjwt is offline   Reply With Quote
Old 12-06-2010, 11:09 AM   #3
dropd80s
dropd80s's Avatar
Try this link:
http://www.pirate4x4.com/tech/billav...465/index.html
dropd80s is offline   Reply With Quote
Old 12-06-2010, 12:22 PM   #4
spudz
spudz's Avatar
looks like the top is ok but how about the bottom part? its real loose. Can I just weld it solid? I dont care if it rattles. I'd rather it make noise and be a little more solid.
Old 12-06-2010, 03:24 PM   #5
Keith Seymore
Keith Seymore's Avatar
Yes - you can weld it up and make it solid. It will just rattle and transmit all the vibration up through it.
Originally, there was a rubber isolator in the base of the shifter (retained by the lower roll pin that you see). Welding it up just short circuits that rubber isolator (if there is any left).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-06-2010, 06:24 PM   #6
spudz
spudz's Avatar
I took it apart, there is nothing in there lol. I am going to weld it! thanks everyone.
Old 12-06-2010, 07:48 PM   #7
spudz
spudz's Avatar
FIXED!!! SO much better now. went from 10in of flop in gear to just 3. I could correct that with some new tighter fitting pins.
Old 12-07-2010, 12:55 AM   #8
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
you could justed have added 2 o-rings and it would be fine i did this and is nice and stiff now
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 12-07-2010, 08:20 AM   #9
Keith Seymore
I think there were a couple different styles, IIRC.
One style with two o rings; a second style with a rectangular sleeve that fills the void.
About every two years we would go through a project to tighten that shifter up, having a library of test pieces made with different rubber, vinyl, polyurethane, solid, etc. Usually in the end we'd just go back to whatever we already had....
:shrug:
K
1979-1986
1986 - 2019
Old 05-14-2020, 09:59 AM   #10
Geb58
Geb58's Avatar
https://www.youtube.com/watch?v=EXIND3xn1xs
GEB
https://www.youtube.com/user/GebBuilt
Geb58 is offline   Reply With Quote
Old 05-14-2020, 02:14 PM   #11
wixthedog
wixthedog's Avatar
That clamp is intersting! I believe there is a grub screw on each side that acts as the retainer. I can only assume that one stripped out so they held it in that way.
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is offline   Reply With Quote
