Old 12-05-2010, 11:00 PM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Trucks being a dink....
So since i bought my truck a few months ago i have replaced pretty much every typical "Maintenance" part right down to the starter and alt. so tonight went out to pick up a new washer and dryer and got to the peoples house and loaded the stuff up and went to leave and the truck slowly rolled over but wouldn't fire so buddy bosted me and we were on our way home. lights seemed a little bit dim but nothing really to bad.
So got home turned the truck off than tried to fire it right back up (no go)
so i unloaded the washer/dryer and than went out and boosted the truck so i could get it away from the door
parked in its spot turned it off (the dash lights and head lights seemed a bit brighter) so i tryed starting it fired right up did it about 6 times and fired right up.
trucks been sitting about 10-15 min now (i'm going to go see if it still will start) *runs out side * started to roll over than made a crunch noise and rolled over really really slowly... this is leading me to believe it's the batt... but it's not doing the clicking noise when i roll it over that a dead batt usually does.
Sorry this is a long post. i was just hoping i didn't need to buy a batt this close to Christmas.
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 12-05-2010, 11:09 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Trucks being a dink....
id check the alternator too make sure the regulator is good in it...
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-05-2010, 11:10 PM   #3
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Check your connections. It happens to my truck when I hook up the battery and its not tight enough or something.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 12-05-2010, 11:26 PM   #4
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
i hope the alt is ok..... i just replaced it a few months ago... i'll do a red neck alt check tomoro and check it out.
Old 12-05-2010, 11:26 PM   #5
bmchevy1979
bmchevy1979's Avatar
check your connections for sure when I first got my 76 running I pulled it into the shop to put the motor for the blazer in the back shut it off because I was going to be there for a little bit and when I went to start it it cranked but not fast enough to start hooked battery charger up and started like the battery was fine drove me crazy for a week it would do it only sometimes not specific (hot or cold) finally double checked connections and what do you know a loose connection at the starter haven't had a problem since
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 12-05-2010, 11:31 PM   #6
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Will crawl under there tomoro and check Thanks!
Old 12-06-2010, 01:37 PM   #7
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
went out today... and started with the starter connection... the plastic and the connection nut were loose to the touch i touched it and its broke off from the starter! i just bought it a few months ago! FML so now i got to pull it out and take it back and HOPE they do something about it.
Old 12-06-2010, 01:44 PM   #8
silvereagle07
silvereagle07's Avatar
I'm sure it has some kind of warranty if you bought it from a parts store. I replaced the starter on my 81 lwb several times before I got a good one from the autochain stores. Good luck.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 12-06-2010, 02:11 PM   #9
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
also found an oil leak near the rear of the motor. (rear main prop :S)
Old 12-06-2010, 03:10 PM   #10
Robert8096
Robert8096's Avatar
Had this happen to an Advance Autoparts brand new starter I put into a GMC s10 Jimmy. Took it back to the parts store and they replaced it at no charge. The counter guy told me they have a lot come back like that because they use such cheep plastic. Good Luck.
Robert8096 is offline   Reply With Quote
Old 12-06-2010, 03:11 PM   #11
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
lol of course it couldn't go bad when there is no snow on the ground.... it's cold under there trying to get that bad boy out :S
Old 12-06-2010, 04:29 PM   #12
Robert8096
Robert8096's Avatar
Don't do snow! It's 47 degrees here and I don't think I am going anywhere near my garage tonight.
Old 12-06-2010, 04:41 PM   #13
splehigh
splehigh's Avatar
I had a similar problem after my truck sat for a while. Truck wouldnt start and only turned over real slow. Here the starter gear was stuck in the fly wheel and wouldnt release. After I got it unstuck it has started ever since. Makes a funny noise now and then but it doesnt look like its damaging the fly wheel so I guess I'll just run it till it dies. I should probably carry a spare. lol
splehigh is offline   Reply With Quote
Old 12-06-2010, 05:56 PM   #14
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
it cost me 20 bucks for them to put a new cap on as apparently it's my fault "i over tightened it" months ago and it decided months later to give up the ghost,,,
Old 12-07-2010, 06:07 PM   #15
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
so got the starter in and all but ran out of day light so tomorrow i have to solder the start power lead back together. not a big deal just ran outa light.
but for fun i hooked the cable up by just twisting them together (temporarily) to see if the issue was gone. still turned slowly but i could hear it sparking to the block. (lol bad idea i know) so i'm hoping tomorrow when i hook the wire up the connection will be better and it will work again if not...
Where do i go from there? all the connection points are clean and tight.
Old 12-08-2010, 02:15 PM   #16
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
This is after i took the starter back. and i watched him bench test it. i'm going to assume it's the batt as the alt is new the starter is new the connections are clean etc.... But my question is why are the lights still quite bright? and why dosn't the starter "click" like on other vehicles?
yay new batt for x mas :S
Old 12-08-2010, 02:45 PM   #17
wyattglock
wyattglock's Avatar
When the battery on my truck got ran down this year, it wouldn't click either. It just sat there making no noise at all. I put the battery on trickle charge of 2 amps overnight and then it started right up. I would try the battery also and see if that takes care of it. Good luck!
wyattglock is offline   Reply With Quote
Old 12-08-2010, 02:54 PM   #18
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
yeah boosting it fixes it (it will start ) but it will some times re start and some times not :S i might just bite the bullet and put a batt in it. when yours was going bad were your lights still pretty bright?
Old 12-08-2010, 06:19 PM   #19
wyattglock
wyattglock's Avatar
Yeah the lights stayed bright even though the battery was junk. Fortunately, the alternator is new and puts out a good charge. I still haven't got the battery setup I want in it, but that will come soon hopefully. I want to run 2 batteries with an isolator between them so they cant do a mutual discharge to one another. That way if one goes bad, I still have the other one to run the truck.
Old 12-08-2010, 07:37 PM   #20
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
guess im off to the auto parts store tomoro to price out optima red or yellow top batt.
To: Truck
Love : Dru
Merry X mas!
Old 12-08-2010, 10:27 PM   #21
bucannon
Salty Sailor
bucannon's Avatar
optima is the way to go, those things last forever
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 12-09-2010, 10:34 AM   #22
wyattglock
wyattglock's Avatar
To: Truck
Love : Dru
Merry X mas!
I would go redtop Optima. They are built for quick discharge bursts, great for starting trucks and running stereos. The yellow tops arent bad either, they are just a longer discharge time.
Old 12-09-2010, 10:38 AM   #23
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Sounds good to me thanks!
Old 12-09-2010, 06:19 PM   #24
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Well put a batt in the truck and fired right up.... Wife wouldn't let me get a Optima Red top (200 + tax) this close to x mas but i got one with a 3 year no questions replacement so i guess it's all good. it was only (83 with taxes)
THANKS FOR ALL THE HELP GUYS!
Old 12-09-2010, 07:40 PM   #25
wyattglock
wyattglock's Avatar
That's awesome! Glad that took care of it for you. I understand about the wife not letting you get the more expensive battery. Mine tends to throw a fit when I spend to much on a hunting trip that she thinks is pointless.
