Someone Please Help Me With My Plug Wires
I've posted before about this problem I'm having with selecting proper plug wires for my truck. As you can see by the picture, these wires are at least two feet too long. They are HEI wires and every set I choose are WAAAAAY too long. Will someone please tell me which wires to buy that actually fit properly?
Big Red - Now its a SWB!
Re: Someone Please Help Me With My Plug Wires
Not sure, but I'm interested too because I'm gonna add HEI soon.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
![]() Join Date: Dec 2009
Cut to fit wires is way to go there.
I used MSD wires, i bought a universal set and custom fit them. They come with the crimper too.
Maybe just wrap the extra around the carburetor a couple times first!! lol I agree with cutting them to length. Get some new ends, route the wires the way you want them, then cut to length and install new ends. I've used the Accel kits and they seem to fit fine, without wires that reach to the tail pipes! (They're yellow though)
MSD cut to fit wires are always the way to go, I used them on my truck and my '94 z28. All that is needed to make them is a razor blade (to cut insulation, but you use the guide on the crimper that is supplied), big channelocks or a vice (to use with the supplied crimpers), and some type of silicone spray/wd40 to help slide the boot over the crimped metal end.
'72 Chevy Longbed 327 w/ 3 on the Floor-soon to be DD '71 GMC Longbed (originally bought project, now parts truck for '72) '94 Camaro Z28 cam/exhaust/gears '02 Chevy Impala-DD for now -Ryan, GM Master Technician |
The reason they're so long is because they're supposed to go down the back of the motor then along the pan rail and up to the sparkplugs. That's the way the factory did it.
No burned wires. They used wire brackets to hold the wires too. |
1980 camaro 350 wires work perfect
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 ![]() ![]() |
Sierra Grande Club
+1 and it looks great.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Check out LMC. they show the wires run properly and they sell the retainers.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=156 Last edited by dznucks; 12-06-2010 at 08:14 AM. |
i like taylor cut to fits
Summit racing has some pretty nice make your own length kits for around 35 bucks.
#13 |
Yea, I ran them down the back and along the pan rail. Now they're only a foot too long.
#14 | |
Besides, I've spent many hundreds of dollars on LMC junk and most had to be returned because of poor quality or fit. |
#15 |
I use MSD wires for a 1975 corvette, route them down back and under the exhaust up the block. Only a few wires are a little long.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#16 |
Keep them long. Before you are done you may want to hang yourself.
#17 |
Thanks for all of the suggestions. Looks like the way to go is "Cut to Fit".
#18 |
I switched to Belden wires a month ago and am loving the way the truck is running.. I did rebuild the dizzzy as well but Belden makes a damn good wire. Oh yeah, they are too long too..
1967 GMC 3/4 ton Fleetside 350 ci Chevy I'd rather do it myself and spend the extra 500 dollars |
#19 |
My son installed some Standard wires on his 69 GMC with the 350 and they worked out very nicely. They are for HEI, grey color with straight boots for the spark plugs. The lengths are good.
The Standard PN is 6870. I can snap a couple of pics and post them if interested. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
