Old 12-05-2010, 11:59 PM   #1
jojoman
aftermarket shackles
these are the shackles that i have in my 87my leaf spring measure 52 inches the frame to the bed is cut where the shackles hit it still has the bump stop rubber thing on it , it hits hard when i hit a bump it only has two leaf springs the big main one and im guessing the smallest last one ok so what i want to know is what drop are the shackles they measure 8in and if i put the other leafs back is it going to raise it back up im trying to get a 6 drop in back or do i have to buy some thing else also if i take the bump stop is it going to drop more.thanks alot for ya helpName:  IMAG0027.jpg
jojoman is offline   Reply With Quote
Old 12-06-2010, 12:03 AM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: aftermarket shackles
you'll need spring hangers they'll lower the rear a little over a inch and a half
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-06-2010, 01:21 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Why don't you flip the front hanger? It will give you another 1' or so.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 12-06-2010, 11:25 PM   #4
jojoman
the thing is that i think it is at a 6inch drop but what i want to know is if I put the leafs back on there will it raise it back up and the bump stops do i take them off also by flipping the front hanger you mean takin it off and actually flipping it bottom up
