Closed Thread
Old 12-06-2010, 02:36 PM   #1
Brad
Out of the carpool lane.
Brad's Avatar
Arrow Inline L6 194/230/250 Power steering bracket
I have only this power steering bracket for a 6 cyl setup. This is roughly a 67-75 bracket. Perhaps you have a need for this and have the other brackets? This is the key bracket and the others could be fabbed up.
No longer for sale.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline
Old 12-29-2010, 10:02 PM   #2
Brad
Brad's Avatar
Re: Inline L6 194/230/250 Power steering bracket
ttt
Brad is offline
Old 12-29-2010, 10:07 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Brad, do you have a picture of one that has been installed?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline
Old 12-29-2010, 10:52 PM   #4
Brad
Brad's Avatar
These pics are courtesy of someone else on the board that recently had a PS bracket thread-not sure who. Anyway....
Oddly enough, I couldn't find any other ones on my computer. I'll have to look some more....
Brad is offline
Old 12-29-2010, 10:56 PM   #5
Brad
Brad's Avatar
After looking at these pics again, my bracket is 1 of 3 needed and it would be difficult to fab up the other 2 brackets exactly like the stock ones. Having said that, I was considering using this bracket and welding up a few pieces to make it fit on my Camaro but found a complete stock setup. If someone needs this particular piece, I'm dropping the price to $50 shipped. I would rather have it go to someone that can use it instead of sitting on my shelf.
Brad is offline
Old 12-29-2010, 10:56 PM   #6
Leroy-B1
do you know if you can by the power steering lines at the local parts house or are they an oddity?
Leroy-B1 is offline
Old 12-29-2010, 11:13 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Definitely interested Brad... since you've been through this before, can you look at the picture below and tell me if these are the 'other' brackets someone would need?
These inlines can be confusing...
-Nate
Old 12-30-2010, 03:59 AM   #8
Brad
Brad's Avatar
Nate,
those brackets look similar to what you'd need but slightly different. I hate to say it, but I wouldn't be surprised if those are for am integrated manifold inline. I can't say for sure.
The crazy thing about the GM inlines is that they had about 5,432 different styles of PS setups and they all did the EXACT same thing! I'm still discovering ones I've never seen before.
Sorry I can't give you a better answer. Hopefully someone else can.
Brad is offline
Old 12-30-2010, 10:44 AM   #9
NC67Chev
NC67Chev's Avatar
Yep, definitely different set-ups. I have two (one from a engine with a/c and one without) and they are different. That's a pic of my 250 above (without a/c). Anyway, I think the below pic is of the complete set-up that Nate is asking about. It also looks like the outer bracket in Nate's pic has been cut.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline
Old 01-01-2011, 09:44 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for the pic buddy. The more I look at your photo compared to mine, the more I don't see the 'cut' portion you refer to above.
I'm probably guessing wrong but does the bracket pictured below the pump attached to the block, followed by the bracket to the left of the pump, followed by the pump itself correct? Why does your pump reservoir look different than mine...?
Brad, I don't mean to deter from your FS thread; these inlines have always confused me. Back to business.
bttt...
-Nate
Old 01-01-2011, 10:31 PM   #11
NC67Chev
NC67Chev's Avatar
Sorry if I confused you, but my set-up is the one mounted in the 4th post. The circled area in the the below pic that you posted is what doesn't look right to me. The bracket that Brad has is the saddle portion for a set-up like mine. Below is another picture that I found, which I think shows the piece that you are missing. You're right though, they are really confusing. I was fortunate to find my set-up complete on an engine.
NC67Chev is offline
Old 01-01-2011, 11:01 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
So the long bracket circled in the post above (2nd pic) should be connected to the circled bracket (1st pic)? Erh... these stupid things!
-Nate
Old 01-01-2011, 11:26 PM   #13
NC67Chev
NC67Chev's Avatar
I'm not sure what the long one in the first pic attaches to , but I think the one circled in the 2nd pic is the alternator adjustment bracket. The set-ups with the saddle have the alternator adjustment built in. I think this diagram might help. I think it also shows that I was wrong with saying your bracket had been cut. It would appear that your set-up might be off of a 63 230, which should still work once you get it figured out.
NC67Chev is offline
Old 01-01-2011, 11:36 PM   #14
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Son of a b......
Thanks for the diagram as it will help me figure this thing out.
You wouldn't consider posting a picture of the 67-72 setup, if you have one, would you? Maybe we can move this to the 67-72 MB so we can get out of Brad's FS thread.
-Nate
Old 01-01-2011, 11:48 PM   #15
NC67Chev
NC67Chev's Avatar
I've got some pictures of both of mine, but I'll have to sit down and go through the last two years of pictures to find them. My a/c set-up is freshly painted in pieces, so I could get some new ones of that one. But mine are from '72 & '74 respectfully....courteous of a couple of Nova's
If nothing else, Brad is getting a lot of bumps But in all seriousness, sorry Brad!
NC67Chev is offline
Closed Thread
