Old 12-06-2010, 04:04 PM   #1
Big bad Green
Big bad Green's Avatar
Face lift to Pre face lift Idea
Hey guys has any one one here taken like a 81 to 87 and change the nose to a 73 to 80?
1968 Chevy K20 Long bed dump truck
1978 Chevy Custom deluxe long bed
1986 Chevy Custom deluxe short bed
1987 Chevy Custom deluxe short bed
1987 Chevy Silverado short bed
1990 Chevy Silverado K5 Blazer
All four wheel drive! All non mutt trucks!
Big bad Green is offline   Reply With Quote
Old 12-06-2010, 05:48 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Face lift to Pre face lift Idea
It's been done several times. I'm going to be doing this swap when warm weather returns to the Hoosier state. It's a fairly common swap, along with the opposite swap. Check the projects and builds section at the top of the page and you'll find some.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 12-06-2010, 09:21 PM   #3
Big bad Green
i looked a round any help please
Old 12-06-2010, 10:09 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Big bad Green it has been discussed a lot, and it has been done by many. Your best bet is to locate a clean 73-80 front clip including core support. If you can't find one, the parts can be bought separately from many of our Forum Vendors. Give Capt Kaos a shout and he can fix you up.
Just so you know, you will need fenders, hood, core support, grill, etc. You will need the year specific body bushings too.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-06-2010, 10:33 PM   #5
Big bad Green
Im looking for a post that shows how Its done
Old 12-07-2010, 12:23 AM   #6
benoit454
Chris
benoit454's Avatar
unbolt your stuff and bolt on the new stuff. You need the wiper linkage or at least posts as well, cover the holes in the firewall where the 81-87 hinges were, and drill new holes for the wiper posts. Headlight and parklight plugs may need cut off and old ones put on not sure. bumper needs changed and brackets unless you plan to use the 81-87 style.
Then as listed, radiator support, fenders, inners fenders, grille, lights, brackets, hood, hinges, maybe hood latch, maybe fan shroud or upper rad mount?
One guy who done it had the psyhcobilly truck I think it was called and done this swap, the other was a very nice looking blazer. It was black I think and on air bags.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 12-07-2010, 12:43 AM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I don't have a post on how it is done, but going from 81-87 is simple compared to the other way.
1)remove everything from the fenders forward
2)remove the 81-87 wipers
3)mount, mark and drill holes for the 73-80 wiper setup
4)weld up the 81-87 hinge holes
5))bolt on the 73-80 parts (use the 81-87 bushings)
Helped a buddy do this to his truck 2 years go.
http://forum.73-87chevytrucks.com/sm...p?topic=9396.0
had a bad 75 cab, bought an 86 donor and swapped it all over.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
