![]() Join Date: Oct 2007
Happy Holidays to all,
Is SAE 90 the correct oil to use on my 1967 3 speed manual? I have a 250 Inline 6 with 3 on the tree. guy58 |
Re: Sae 90
You could run that, or an 85/140....the old 3 spds ran a pretty heavy gear oil, & I see you are in the southwest. crazyAl
http://community.webshots.com/user/hotrodhorn |
Thanks for the reply.
I am running Lucus 90 weight in my rear-end. Does Lucus make a 85/140 weight? Can I use Lucus oil, or is there a special name brand Chevy used for the transmision? Guy |
Parts and more parts
Re: Sae 90
If all else fails, just put mineral oil in the tranny. Yep, I laughed too, but the dealer had us do that to a tranny on one of the County Highway Department trucks. It was done to solve a hard engagement problem with the tranny. It was still working when I left the shop for another job.
Frank |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Sae 90
If you're considering synthetic, take a look at Redline MTL. It's formulated especially for use in manual transmissions and is designed to improve synchro operation. I ran it in our old Miata.
Re: Sae 90
AFAIK, Chevy used straight 90W GL-4 in these transmissions.
Straight 90W is no longer carried at any auto parts in my area for the last decade or more. The modern equivalent would be 85/90W, with GL-5 being most prevalent. You should run GL-4 in the transmission because of the brass syncros - something to do with sulphur content, I think. I have been running GL-5 in mine with a recent tear down due to bearing failure at 250,000 miles - no syncro problems I could see other than normal wear and tear.
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater. |
Thanks guys
I will use 85/90W with GL-5 if I can not find GL-4. heyjoe Could you pass the name brand and where to get it on to me? guy58 |
Re: Sae 90
Hey GUY58
No brand name in particular. Most the oil companies package this, it pretty much depends on what your local auto parts store happens to carry. Me, I get whatever's the lowest price.
