Old 12-06-2010, 09:58 PM   #1
blackout
blackout's Avatar
Exclamation Help! where does this starter wire go
I have a 1987 Chevy Scottsdale
Originally 6.2 diesel switched to a small block 350
I need to know where this pink ignition wire on the starter goes to
And this green and yellow connector from the trannsmission go to
the transmission is an TH350
blackout is offline   Reply With Quote
Old 12-07-2010, 12:39 AM   #2
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Re: Help! where does this starter wire go
The pink wire should have been for your automatic glow plug modulator. You don't need it anymore. As for the wire connector from the transmission... probably from the TPS for a kickdown, but that's just a slightly-educated guess. My 6.2 had a 4l80E on it, with a computer and TPS for the kickdown. And the older ones I've seen for a TH400 are vacuum driven with no TPS (and I have no idea how they actually work).
Does it run and drive without that connector hooked up? If it does, then I'd be willing to bet that it was a diesel specific part.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 12-07-2010, 12:56 AM   #3
blackout
blackout's Avatar
hmm I think you are right about the transmission plug. But Before i put that engine in i had it in a suburban and it still had the pink wire on the starter and I forgot where it went, does it go to the distributor or something? So i know its not a glow plug modulator
Thanks for the Help!
Old 12-07-2010, 02:36 AM   #4
lindstromjd
Does it go to the power side of the starter or the solenoid side? If it's power side, it might just be another power feed for the fuse block or something. I'm not sure. I was thinking the pink wire was left over from the diesel engine. I don't believe anything goes directly from the starter to the distributor; the two wires going to it (if it's an HEI) would be power-to-coil and tach reading. So I don't know where else that one could go.
-357 / 700r4
-350 / TH350
Old 12-07-2010, 08:06 PM   #5
blackout
blackout's Avatar
The distributor is a HEI. It goes on the solenoid side...man im really stumped on this.. wiring diagrams are useless to
Old 12-07-2010, 08:22 PM   #6
csb#356
If its on the small terminal of the starter then it goes to the neutral safety switch or just to the ignition switch if its a manual, but thats weird because its usually purple. The only wires I've heard of coming from a th350 are for the lock-up torque converter, But not positive because I've never seen that.
csb#356 is offline   Reply With Quote
Old 12-07-2010, 08:34 PM   #7
blackout
blackout's Avatar
I have a purple wire going to the solenoid, then the a 1 gauge red wire that goes to the positive terminal on the battery, then that pink wire
Old 12-08-2010, 12:06 AM   #8
csb#356
Let me make sure that I'm understanding this right. That pink wire is on the same terminal as the battery cable. If this is the case then that wire should run to the junction block on the firewall. Hopefully someone else will chime in on this if I'm wrong. I am not familiar with anything from the 80s especially something that used to be diesel.
Old 12-08-2010, 12:44 AM   #9
jkade
jkade's Avatar
my 86 6.2 only had 2 wires on the starter.... the power from battery and the purple wire from the ignition switch... mine was military though. The other plug, I think mine had that and I cut it out of the harness.
jkade is offline   Reply With Quote
Old 12-08-2010, 01:09 AM   #10
lindstromjd
Solenoid side should be neutral safety switch then.
-357 / 700r4
-350 / TH350
Old 12-12-2010, 08:36 PM   #11
blackout
blackout's Avatar
Thanks for the info guys ...I figured it out,, in the truck i got the engine out of the purple wire was cut halfway in the harness so they replaced it with a pink wire to the 's' terminal on the solenoid..so that pink wire was extra
