Old 12-06-2010, 10:35 PM   #1
brans72
shock relocators ?
I was wondering will using shock relocaters raise truck any when using jeep tj springs? I ask cause I wanna cut my front springs for now but not sure if I need the relocaters before I cut front spring. I am also using new KYB Shocks and truck is a 67 C10 SWB 350/700r4. Brandon
brans72 is offline   Reply With Quote
Old 12-07-2010, 01:01 AM   #2
SCOTI
SCOTI's Avatar
Re: shock relocators ?
Anytime you use shorter springs in the rear on coil trucks, you'll benefit from the shock 'relocators' as they will restore travel length for the shock & return it to a better (more upright) angle allowing the shock to 'work' properly.
That being said, it's not mandatory to use the relocators. You can always do the drop & see how things work as is (measure the travel dimensions @ ride height). If the dimensions indicate the need to change the shock travel, get the relocators then.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
