View Poll Results: which one?
good trade? 16 44.44%
bad trade? 20 55.56%
Voters: 36. You may not vote on this poll
Old 12-06-2010, 11:24 PM   #1
jakeblues652
jakeblues652's Avatar
engine trade vote.
ive been talking to a guy from my area on facebook that has a 71 gmc, and he needs a 327 which i happen to have. he said hed give me a rebuilt'some assembly required'(it was never put back together) 350. what do you think? worn out 327 for a fresh 350?
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 12-06-2010, 11:42 PM   #2
1968CHEVYC10
1968CHEVYC10's Avatar
Re: engine trade vote.
Buying a motor in pieces would kinda scare me, idk just make sure it's all there, little missing pieces could end up costing more than you thought.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 12-06-2010, 11:43 PM   #3
SeventyOne
The way you describe the trade sounds like a good deal. BUT I have to ask why a person would trade a rebuild (needing assembly) 350 for a tired (needing a rebuild) 327.
He wants a straight trade? No $ involved? I just don't see the logic here on his part which makes me think you are not getting what was offered to you or the guy is a saint. Me thinks not
SeventyOne is offline   Reply With Quote
Old 12-06-2010, 11:44 PM   #4
Hubscrub
Cruzin
Hubscrub's Avatar
i would rather have the 327
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-06-2010, 11:50 PM   #5
jakeblues652
the 327 has a bad bottom end knock at idle.
Old 12-07-2010, 12:05 AM   #6
SeventyOne
And the other guy knows this? This whole deal doesn't bother you? I'd be really wary.
Old 12-07-2010, 12:08 AM   #7
67chevy1series
67chevy1series's Avatar
327 are so uncommon in our trucks they almost always have 350 i say keep the 327 and fix it
67chevy1series is offline   Reply With Quote
Old 12-07-2010, 12:22 AM   #8
jakeblues652
yeah, i told him it knocks, and it didnt bother him any. and im not that wary about it cause hes a local. and hes a straight shooter. its not like one of these craigslist deals where you see them once in your life and they can BS you around. and now im considering body panels. he has almost anything a guy could ask for with 67-72's. he has 6.
Old 12-07-2010, 12:45 AM   #9
67chevy1series
man i have a feeling you will get scroowed you told him the porblem and he didnt think twice that doesnt sound good
Old 12-07-2010, 12:48 AM   #10
treveiger
treveiger's Avatar
bottom line be CAREFUL.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 12-07-2010, 03:00 AM   #11
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I'd go through the stack of parts and get as many details as you can. Ask what the overbore is, what the crank journals are turned to, ect, ect. Find out what machine work was done on it, and what parts he has. I agree it can add up quick if you need to get parts to put it back together. If all is well then I say you are getting a good deal, you can't tell if its a 327 or 350 by looks anyway so you can call it a 327 if you want when people ask whats under your hood.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-07-2010, 03:49 AM   #12
CCCC
CCCC's Avatar
I would never trade a known but tired (even knocking) 327 for an unknown 350 still in pieces. I think that the 327 is a better performing and better balanced engine - and getting a bit scarce. I would rebuild the bottom end if that is what it needs.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 12-07-2010, 08:57 AM   #13
slomotion
Old Duffer
slomotion's Avatar
Sounds like no matter which way you go, you're going to have to build it. 350's are everywhere...build the 327 and keep it. JMO
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 12-07-2010, 09:56 AM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if the 327 is worn and knocking... it's worth very little without a rebuild. Without being inspected, you don't even know if the block is worth rebuilding.
So worst case scenerio... you may spend just as much on the 350 that you may end up spending on the 327.
An engine that is questionable is to be considered scrap metal untill proven good.
Old 12-07-2010, 10:19 AM   #15
VetteVet
Msgt USAF Ret
VetteVet's Avatar
IMO it's a no brainer. You've got an engine that's about to grenade and some guy has a dis-assenbled 350 that's been rebuilt that he wants to trade for it. He probably wants a 327 for a period correct restoration or he just wants a 327. I'd look at the parts and if they looked fresh and new I'd trade in a minute. There's probably $300 tp $500 worth of parts for the 350 and even if the block is cracked there are tons of them around.
There's lots of reasons for the 350 to not be assembled besides something being wrong with it. Like LMH said the worst case scenario is about what you've got now with the 327. My .02
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-07-2010, 10:40 AM   #16
68jewel
On the path to financial ruin!
68jewel's Avatar
Maaaan, keep your motor and rebuild it or go get your own 350. I've just about had it up to here with questionable deals. Just because a guy is local doesn't mean anything. Unless you know and truly trust him...beware. Yeah, there are alot of variables, such as him wanting a period correct 327, etc. But, be careful is all I'm saying.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS
'68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame
Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280
68jewel is offline   Reply With Quote
Old 12-07-2010, 03:53 PM   #17
68 IRON
68 IRON's Avatar
I agree with Longhorn. Your 27 is running with a known area of concern versus a 50 not assembled and called "rebuilt". You know what you have but dont with the other. Who knows.....did he find one or more major components with flaws (cracks, bent or mismatched). In a box it might look good, but a cracked block and crank, mismatched rods/ pistons and warped heads could be all you get. For these reasons......bad trade.
68 IRON is offline   Reply With Quote
Old 12-07-2010, 03:54 PM   #18
68 IRON
68 IRON's Avatar
Besides..... 327 sounds more exotic!!!
Old 12-07-2010, 03:58 PM   #19
tubbedII
needs more $$$
tubbedII's Avatar
It's really hard to say without knowing more about what he's offering you, but IMO, as long as the parts look to be in good shape, I'd go for it. Of course it's a risk, but what purchase/trade isn't? The question you need to ask yourself is, do you want a 327 or a 350?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 12-07-2010, 05:19 PM   #20
brad_man_72
the boat guy
brad_man_72's Avatar
scares me! But then again I've been running a 5.3 condition unknown sat for 2 years in my truck for amost 2 years. Neer had the valve covers off. Good luck!
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 12-08-2010, 10:50 AM   #21
What is meant by "rebuilt with some assembly required"? I visualize at least a short block assembly,if not a long block,with some parts still not installed.Like the push rods and rockers aren't installed.It's not rebuilt if it isn't assembled.
Personally,with all other considerations aside,I'd do whatever it takes to have the 327.Some automatically go for more cubes.Some go for more rare.Some like common.And,some like vintage.I like more from less and the 327 is the perfect platform for that.And...they haven't been used for 42 years and you don't see anyone building new crate 327s.The fact that it's a piece of history from the coolest car manufacturer in the world makes up for any other short comings.
Old 12-08-2010, 11:14 AM   #22
1949gmc
In a case like this, i think I'd only trust what he was telling me about the 350 if I were related to him (and even that's questionable sometimes) or if he's been one of my best friends for years. Or, I guess, if he were one of those guys that has an outstanding reputation for being a good guy, you know... drop everything to help someone in need kinda guy. I mean, who's to say that the 350 block doesn't have a hairline crack somewhere or that the crank snout is bent. You can't just give these parts a 'once over'. You'd really have to do some serious work with a mic and go over the block, and all the pieces, really carefully to know for sure. Has the block been bored or just cleaned up with a hone? It might be .030 at the top of the cylinder but .005 at the bottom. Would you be comfortable with a block like that? I wouldn't.
And chances are, if you found a problem with the 350 after you got it, he'd probably say you were SOL.
1949gmc is offline   Reply With Quote
Old 12-08-2010, 12:43 PM   #23
LockDoc
The Older Generation
LockDoc's Avatar
I guess my big thing would be if he has receipts for parts or work done. I'm guessing the 327 in the condition it's in is worth 300-400 bucks. Your call...
LockDoc
Leon
Old 12-08-2010, 03:15 PM   #24
Ackattack
Ackattack's Avatar
yeah, I'd ask for reciepts from the machine shop so you know what has been done, and then verify by looking for machining marks in the bores, journals, etc.
Ackattack is offline   Reply With Quote
Old 12-09-2010, 12:31 AM   #25
1970 CST STEP
if you got a number, call the machinist, he will tell you what you need to know
1967 SWB (small window) original
1970 4x4 STEP
1970 CST SWB FLEET
1972 SWB FLEET ORIGINAL
1970 CST STEP is offline   Reply With Quote
