12-07-2010, 12:58 AM | #1 |
Need help finding numbers on my rear end
I have a rear end off of a 71 cheyenne and want to find the rear end numbers on it to see if i can find the gear in it without cracking the case off. Where are all the numbers on the rear end so i can start sanding in the right place this time.
1969 Chevy c20(Miss Hackjob) |
12-07-2010, 02:53 AM | #2 |
Big Red - Now its a SWB!
Re: Need help finding numbers on my rear end
I say pop the case and change fluid while in there. It's easy and it will love you for it!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
12-07-2010, 06:54 AM | #3 |
The Older Generation
The code is stamped on the passenger side tube of the rear end housing. Should be three letters and some numbers. The three letters are what you are looking for. The earlier housings only had two letters. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-07-2010 at 06:58 AM. |
12-07-2010, 08:29 AM | #4 |
On a 72 they are right here. You can barely see it in the pic.
72 Cheyenne Super 80 Silverado Blazer 2wd |
12-07-2010, 01:03 PM | #5 |
Thanks gus, the oil will get changed after i sand blast it and get it painted to put on, its in the box of the truck right now .
12-08-2010, 08:55 PM | #6 |
12-10-2010, 04:47 PM | #7 |
Dude, just drop trou and back up to a mirror!
12-10-2010, 11:02 PM | #8 |
the sad thing is it took me a while to get the joke...
12-12-2010, 09:28 AM | #9 |
numbers on the tube might tell you what gear was in there 40 years ago. only way is to open cover.very easy and will show if gears are worth using.
12-12-2010, 09:56 AM | #10 |
I'd do the spin and count method if you aren't sure if you are using that rear.If you are using it I;d do as others suggested and remove the cover to read numbers on the ring gear.Either way,you could always dump the same oil back in if you decide not to use it.
12-12-2010, 11:12 AM | #11 | |
Zzzzactly, you never know who has been there or what they have done.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
12-12-2010, 03:11 PM | #12 |
Too funny! If you need to find out what numbers are on your rear end, you must have had one hell of a night of drinking
12-12-2010, 03:28 PM | #13 |
That now that's comedy right there boys!!!!!!!!!!!!!!11
12-12-2010, 04:49 PM | #14 |
My Carbon Footprint
I once sat on my son's alphabet and ....... lol
Those questions are always the funniest when you first see them posted. I have seen variations of these: "there is a noise coming from my rear end" "my rear end feels all sloppy and loose" "I have some fluid leaking from my rear end and it smells funny/burnt" "my rear end just locked up on me the other day" Om man......my guts hurt just writing that. I've seen it all on here! |
12-12-2010, 06:00 PM | #15 | |
As long as there's no "dribble" on the front-end
12-12-2010, 06:44 PM | #16 |
Its amazing how different things can sound to different people
1969 Chevy c20(Miss Hackjob) Last edited by treveiger; 12-12-2010 at 06:45 PM. |
12-13-2010, 04:44 PM | #17 | |
Those are even funnier than the "Engine Missing -- Please help!" thread titles
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
12-14-2010, 01:44 AM | #18 |
LOL. Yes, quite naughty...eeew, not in a good way
Best Regards, Leon 1970 C/10 LWB Cummins Turbo - Build in Progress Many other toys as well... |
