12-07-2010, 12:57 PM | #1 |
big tires
what are the widest tires i can fit on a 71
12-07-2010, 01:01 PM | #2 |
Re: big tires
I've got 31x11.5's on mine, pretty good clearance, and I've heard guys running 12.5's with no issues
'68 C10 LWB 6.2NA/NP833 3.73's |
12-07-2010, 02:56 PM | #3 |
Re: big tires
here is my 315/35/20 on my truck before I tubbed it. I think with a little bit of lean, the tires would have rubbed the wheel well.
[IMG][/IMG] |
12-07-2010, 04:00 PM | #4 |
Re: big tires
Need more info. Whats size wheel and width do you plan? How much drop? Stepside or fleetside?
12-07-2010, 11:48 PM | #5 |
Re: big tires
its a fleet side
the front is droped 3in and ass is still stock height im not sure what size wheels theres a guy on base whos got some 15x15 wheels that hes getting rid of wanted to see what i need to do to fit those under the truck |
12-08-2010, 12:03 AM | #6 |
Re: big tires
Need a rim w/ alot of backspace (6.5") i think you can run 29x15.5 easy
1967 SWB (small window) original 1970 4x4 STEP 1970 CST SWB FLEET 1972 SWB FLEET ORIGINAL |
12-08-2010, 09:14 AM | #7 |
Re: big tires
this is a 295-45-20 and it is as wide as i could go without any mods to the bedside or inner fender...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
12-08-2010, 09:42 AM | #8 |
Re: big tires
I'm pretty sure you can't fit a 15x15 wheel without mods. I think a 10" wide wheel is about the max, at least with a decent tire. You could maybe fit an 11 or 12" wheel with the right tire size, but still may have some rubbing issues.
The 15" wide wheels may fit without notching the frame, but will require bed mods. Hopefully someone with more knowledge will comment.
12-08-2010, 10:07 AM | #9 | |
Re: big tires
12-08-2010, 11:07 AM | #10 |
Re: big tires
I'm running 31 x 16 x 20's on mine. 20 x 12's with a 6" BS, 5" tubs....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
