![]() Join Date: Sep 2005
which transmission
i was told for my 71 c-10 i'd want a turbo 350 with long tail shaft or a th400 with longtail shaft so i can reuse my driveshaft does this sound right?
71 c-10 lwb
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: which transmission
all these trucks came stock with short tailshaft 350 tranny i'm not sure with the 400 what tailshft
350 and 400 tranny need different driveshafts
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 12-07-2010 at 02:21 PM. |
My 68 lwb came with a 400 which i thought only had a short tail. Did not know it had different ones like the 350 had over time.
its all about the +6 inches
If your truck had a long shaft tranny installed at one point, then your info is correct that this is what you need to locate. However, as stated above, the original TH350s in the 69 - 72 trucks were in fact, short tailshaft assemblies.
okay i am tryign to figure out what i need to convert i got the column linkage brake pedal
just need the trans cross member and lines and tv cable so i need a th350 with short tail? do i need a whole another drive shaft or yoke?
longhorn nope just the stock 3 speed manual
th350 doesnt have a tv cable it's got a kickdown ca
you'll need a cooler and lines. A rad with a built in cooler is prefered
yeah i knew about teh line and cooler
1967 SWB (small window) original 1970 4x4 STEP 1970 CST SWB FLEET 1972 SWB FLEET ORIGINAL |
yeah i know i call them all the same thing lol
If you have a 3 speed manual now and you want to keep the same driveshaft you need a short TH350.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
#13 |
kk thats what i wanted to know
#14 |
![]() Join Date: Jun 2010
I'm in sort of the same situation. I have a 350 long water pmup motor with a turbo 350. The tailshaft measures 9". Is that a long tail or short tail?
I have a driveshaft from a 68 6 cyl 3 speed manual trans truck. Should that fit my transmission? It doesn't seem to go in too easily. Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#15 |
He the th350 I took out couple weeks ago it's 6in tail. Why not put a 200 4r or 700 4r? I put a 200 r4 overdrive
Posted via Mobile Device |
#16 |
Well I already own the th350 and want to get the truck running with that.
#17 |
![]() Join Date: Dec 2009
TruckDude are you still looking for a transmission? I have a 350 short tail in my garage taking from my buddys 72 C10. I was going to rebuild it and see if anyone local needed it due to shipping. Your about hour and half from me. Brandon
#18 |
i do not at the time i picked one up the other day but the condition is unknown
#19 |
what would you want for it after being rebuilt?
#20 |
pm me for me need more info from you on what you want. Brandon
