Frame mounted trans cooler only?
Just like the title, is it ok to run a frame mounted trans cooler without running lines to the radiator? I know I have seen some build threads that people have done it, but I'm having a hard time finding much in my search efforts. I won't ever be pulling anything with my truck if that matters. Oh and the tranny is a 460le behind a 5.3 engine. Any help with this would be awesome!
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=391224 |
Re: Frame mounted trans cooler only?
you might have the tranny too cool for optimum operation// the radiator gives that needed warmth to fluid
Moderator
![]() Join Date: May 2007
It is called an auxiliary cooler for a reason....to be used in addition to the heat exchanger in the radiator. Water transfers heat more efficiently than air, so I would not bypass the heat exchanger. As told to me by a design engineer at GM.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
sharp as a marble
![]() Join Date: Jan 2007
I agree with both of the above. Transmission fluid needs to be at a specific temperature, and the Radiator tranny cooler does this and then keeps the fluid at that temp ( around the same temp as the water in the radiator ). I run a line into the radiator cooler, then out of the radiator, then thru the aux cooler and then back to the transmission. Now the real question? Why would you want to risk a $2000 transmission for about $100 worth of parts, and 2-3 hours of your time?
#5 | |||
In my humble experience, the above is right on - correct way to do it for more than one reason.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
