Should I paint or clear my new parts?
I recently purchased all new balljoints, tierod ends, and control shafts. My question is, I really like the look of cast iron, should I paint my new parts with cast iron engine paint or clear them. I just don't want them to rust in the future. What is my best option?
![]() Join Date: Mar 2010
Re: Should I paint or clear my new parts?
I have had better luck using cast blast paint. It comes in a spray can and looks just like cast iron.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
The Older Generation
I think I would paint them with the cast block paint. Clear doesn't seem to last too long on that kind of stuff... My 2¢ worth LockDoc
I say paint em. Some parts have a different tint if left natural and would show more if cleared.
72 Cheyenne Super 80 Silverado Blazer 2wd |
![]() Join Date: May 2007
If you clear over the bare metal, they WILL turn brown under the clear.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
Looks like I will be painting them. What is the best cleaner for these parts? Brake parts cleaner? Also do you think I should put these parts in an oven and heat them after paint?
dont put them in the oven simple room temp air dry will be totally sufficient. I highly recommend cast blast or (rebuilders cast finish) by plasticoat. clean em with brake cleaner or wax and grease remover and a little scotch bright theyll turn out great
To clean them, use some kind of a paint prep solvent... Eastwood's Pre Cleaner or Napa's 6383 Kleanz Easy Surface Cleaner. I wouldn't use brake cleaner. And don't put the parts in an oven! You'll melt all the grease out of the ball joints and tie rods and make a mess.
Wipe em down, shoot em with a rattle can, install, enjoy. |
So,, what else you got???
![]() Join Date: May 2010
Aeresol brake cleaner does a good job of cleaning,,,, but,,, it just dries to quickly. It usually dries before it removes anything, meaning you have to keep spraying it on.
I used the POR15 Degreaser, Marine Clean. It worked like a dream.
Trevor "You already said spite" |
