12-07-2010, 10:02 PM | #1 |
Simple Security
Quick write-up of my hood latch lock. The idea is to require more than the stock hood plate being pulled up to open the hood, keeping prying eyes out. I saw this done on the forum, so I went about recreating it.
You will need: A grinder with a cut wheel or a good dremel. A remote cable, I got mine at autozone for 7 bucks. A drill with a small metal bit. 1. First step is to remove the hood latch plate. 5 bolts should do it. 2. Next you drill a slot on the pull plate where it contacts the hook. The pull plate is on a pivot, and when it contacts the hook it pivots the hook out of the way of the hood. With this slot in there there is nothing pivoting the hook out of the way. You can see the grind marks around the slot I made. The front of the truck is on the right, looking up from underneath. 3. Drill a hole in the hook through which you will feed your cable. I kept my hole small and in the corner. There won't be too much stress so I don't think it will be a problem. 4. Route your cable being careful not to crimp or bend it too much, it makes it difficult to use. Also do not put too much tension on it, and make sure there is not too much slack. Here you can see how I bent the wire to keep it attached to the hook. Didn't have a crimp handy so I just rigged it. I can finalize it later but it's stable so no biggie. You can also see where the pull knob is routed under the bumper. Initially I had it come out of the bottom of the license plate, but I didn't like bending the plate to pull it all the way open so I moved it. Eventually I will get a couple of spring loaded hinges from a car with the fuel nozzle behind the plate, and do that to my license plate, drill a hole behind a bottom license plate hole, and route it that way, but for now this will do. 5. Remember not to bend your line too much. Also remember that the point of this is to be a covert latch system, don't run your wire down in front of your radiator where anyone can follow it to the pull knob. Don't drop your hood until you know it's working 100%, it's annoying to push the hook back if you close the hood. For running the line I used stock holes in the core support, and attached a picture frame hanging triangle thingy. It has a tab you screw into, and a triangle that can swivel connected to it. Routing into the cab is best, but I don't have lock on my doors yet so it was just a matter of streamlining t for now. Hope it helps someone out. Go ahead and suggest changes, always good to keep the truck safer. |
01-14-2011, 02:29 AM | #2 |
But Found Her 25yrs Later!
Re: Simple Security
It appears this thread has been overlooked.
I'm starting to try and think of ideas to make my truck more secure. Thanks for posting this.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 01-14-2011 at 02:29 AM. |
01-14-2011, 08:43 AM | #3 |
Re: Simple Security
Could someone give those pictures a little help? Probably why it was overlooked. I can't really make anything out enough for them to help.
01-14-2011, 09:09 AM | #4 |
Re: Simple Security
Or you could simply install two things; A battery Disconnect and a Ignition cut-off switch hidden in the Cab. That's what I use.
Then again I have a locked garage I keep my truck in, so if someone breaks in and takes the time to get it running while the alarm is going off, then more power to them. Of course if I'm home....then it's me with my pals Smith & Wesson. I guess the hood latch would be good for those who keep their truck outside. Jeezz, I just about throw up anytime I think about leaving mine outside.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
01-14-2011, 09:40 AM | #5 |
Re: Simple Security
Those are good ideas to keep your truck from being stolen but the cable system shown here is a good way to keep your battery, carb or any other expensive parts found under the hood from being stolen.
1970 GMC truck 1988 Harley 1200 Sportster |
01-14-2011, 09:56 AM | #6 |
Re: Simple Security
Like I said, it's a good idea for guys who keep their trucks outside.
01-14-2011, 10:03 AM | #7 |
Petroleum User
Re: Simple Security
Good idea. I actually took my battery in the house when I went out of town...duh. I cant believe they made the latch on these accessible to the general public! Double duh.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
01-14-2011, 10:14 AM | #8 | |
Re: Simple Security
By the way the next day I mounted a limit switch on the inside of my fender, it’s resting on the hood hinge and is wired to a car alarm siren that I had laying around, so that when the hood is lifted any more than about three inches the alarm goes off. I should be able to hear that baby screaming a mile or so away next time.
Mark 1967 C/10 stepside lwb daily driver 1968 C/10 fleetside lwb parts truck 1971 Cheyenne Super swb project |
01-14-2011, 11:43 AM | #9 |
Re: Simple Security
I had this saved
http://67-72chevytrucks.com/vboard/s...t=hood+release
1967 K-20, 1969 K-20, 1970 C-30 dump,1971 K-20 1972 K-20, 1972 C-10, 1968 Grandprix John Deere 350c Dozer, 3414 International backhoe 1972 International 1600 Flatbed |
01-14-2011, 02:01 PM | #10 | |
Petroleum User
Re: Simple Security
01-14-2011, 06:00 PM | #11 |
Re: Simple Security
01-14-2011, 06:32 PM | #12 |
Cruzin
Re: Simple Security
people were alot more honest in the older days.......
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
01-14-2011, 08:24 PM | #13 |
dazed and confused
Re: Simple Security
members met: redbaron69, billsbowtie,nc67 |
01-14-2011, 08:46 PM | #14 |
6>8 Plugless........
Re: Simple Security
It's a good idea for anyone who drives their truck and doesn't get the opportunity to be with it the whole time it is parked. Nice write up.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 01-14-2011 at 08:47 PM. |
01-15-2011, 12:55 PM | #15 |
Re: Simple Security
I have a battery shutoff switch, and my truck stays in a locked shop. I have a buddy who has a 69 burnt to a crisp sitting outside his shop. It burnt because of a short. There are other advantages to having a shutoff switch also, it makes it nice to work on anything electrical and not having to disconnect the battery every time.
01-17-2011, 12:04 AM | #16 |
Re: Simple Security
Battery shutoff is goin on next. Plannin on a whole buncha relays.
