Old 12-07-2010, 10:56 PM   #1
unreconstructed1
nec absolutum
unreconstructed1's Avatar
heater question...
On my 97 K2500, regardless of where my temp controls are set, the dash vents ALWAYS blow hot air. I was thinking it may be the climate control itself, but I was curious if it was something else. defrost and floor vents work, but even when they are blowing that danged dash vent is still blowing hot air. makes it a PITA considering where the cup holder is. so, any ideas?
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants."~ Thomas Jefferson
1967 GMC C1500 LWB 250/3 on the tree-
1969 Chevy C/10 SWB 350/TH350
1996 Chevy Silverado LWB 350/4L60E
1997 Chevy K2500 350/4L80E
unreconstructed1 is offline   Reply With Quote
Old 12-08-2010, 12:02 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: heater question...
I'm going to guess that the blend door motor is not working properly. It is not unusual for this to be a problem. Here's a pic of an HVAC unit. The blend door is in the general area behind the radio. Do a search and you'll find numerous posts as well as some How-To instructions.
Member Nr. 2770
Old 12-08-2010, 11:16 AM   #3
ChevyTech
The temp door motor is the one in the center of the ductwork.
Remove the glove box and watch & listen for movement when you change the temp on the control. The motors are a high failure part.
You can put your hand on it and feel if the motor runs or not.
Old 12-08-2010, 09:03 PM   #4
unreconstructed1
nec absolutum
thanks guys. I'll try this.
