Old 12-08-2010, 02:21 AM   #1
agent orange
agent orange's Avatar
Front Drum brakes??
I just found out this morning my wheel cylinder is bad...Does anyone have a pic of the rivets i need to cut/grind to take the drum brakes off? I know there are several threads but could'nt find any pics of the rivets. Please help!
I have a 66 GMC
1966 GMC Current project
1966 Chevy C10 Sold
1985 C10 Sold
1968 El camino Sold
1954 Ford Anglia Sold
1973 GMC Suburban Sold
1974 Chevy C10 Sold
agent orange is offline   Reply With Quote
Old 12-08-2010, 02:34 AM   #2
raycow
Re: Front Drum brakes??
If you just want to look at the brakes, you don't need to cut off any rivets. Just pry off the grease cap in the center of the hub. Then remove the cotter pin and unscrew the nut. The hub and drum will pull off together.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-08-2010, 02:50 AM   #3
agent orange
Ray
Thanks!..Once that's done are the rivets on the wheel cylinder the needs to be grinded off?
1966 Chevy C10 Sold
1985 C10 Sold
1968 El camino Sold
1974 Chevy C10 Sold
Old 12-08-2010, 03:32 AM   #4
raycow
No rivets. The wheel cylinder is bolted to the backing plate.
Ray
Old 12-08-2010, 03:53 AM   #5
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
I just replaced my brothers wheel cylinder and it didn't have any rivets. Pretty easy to do, but just remember how you took it apart.
kalirodding is offline   Reply With Quote
Old 12-08-2010, 04:55 AM   #6
agent orange
Thanks for the help!...I will tackle it first thing in the morning after a fresh cup of
1966 Chevy C10 Sold
1985 C10 Sold
1968 El camino Sold
1974 Chevy C10 Sold
Old 12-08-2010, 11:03 AM   #7
geezer#99
geezer#99's Avatar
If indeed your cylinder has been leaking you'll need to replace the brake shoes too.
And you mights well replace the flex hose on that wheel too.
And check the cylinder and shoes on the other side.
Old 12-08-2010, 11:18 AM   #8
TheDark1
Intentionally Left Blank
TheDark1's Avatar
The rivets hold the drum to the hub. The whole assembly can be removed by taking the wheel bearing nut off like the guys said above. If you don't want to mess with grease and bearings, you can grind off the rivets and remove just the drum. I had to remove the rivets on mine to get the wheels to seat flat against the drum. Someone might have taken the rivets out previously also. The rivet heads are in between the wheel studs. I think there are three of them. Hope this helps, Jeff.
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
