Old 12-08-2010, 04:07 PM   #1
KIC
1960 GMC Burb
KIC's Avatar
1960 Inside panel removal - HELP !
Hi my favorite truck Gurus,
I am moving along on my 60 GMC Suburban. I tried to remove the inside front door area panels shown below. They seem to be "glued?" anybody ever removed these ? Is it better to sand and paint them in place ?
Thanks in advance for the forthcoming great advice.
1960 GMC Suburban
1/2 ton V-6
2nd generation original owner
60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban
60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs
2003 Tahoe LT
KIC is offline   Reply With Quote
Old 12-08-2010, 05:31 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 1960 Inside panel removal - HELP !
I haven't removed them , but buy looking at the pics, they have to be screwed or spot welded somewhere around/behind that door rubber..
Old 12-08-2010, 07:55 PM   #3
KIC
1960 GMC Burb
KIC's Avatar
There doesn’t appear to be any welding. No screws, kinda crimped behind the rubber molding. But, the panels don’t really move when the screws are out. Somebody thought that they (factory) might have “glued” them and used the screws along the back. Just wondering if anybody knew how this was done, or how they removed them without causing damage to them. I’ll just sand and paint them inside if that is easier.
1960 GMC Suburban
1/2 ton V-6
2003 Tahoe LT
Old 12-08-2010, 11:51 PM   #4
rustyrodknocker
I'm new on the site but not to the site. but I know the answer so i'll jump in. Both of those panels are welded also. the spot welds under the weatherstripping for the rear panel and along the front edge of the one over the door. I just pulled them out of my burbans a couple weeks ago. had to drill about 25 spot welds on the chev and was able to break them by hand on the gmc. no fusion.
rustyrodknocker is offline   Reply With Quote
Old 12-09-2010, 12:45 AM   #5
KIC
1960 GMC Burb
KIC's Avatar
Thank you. That answers my question. They get sanded and painted IN the Burb !
1960 GMC Suburban
1/2 ton V-6
2003 Tahoe LT
Old 12-09-2010, 10:04 AM   #6
jonzcustomshop
1961 crewcab
Great first post!! thanks fo the info, I have been eyeing a pair at the wrecking yard... now I know they will be a little more difficult to take off.
