Old 12-08-2010, 06:39 PM   #1
jasons
not enough hours in the day
jasons's Avatar
Floor hump? putting 2wd cab on 4x4
I have a 74 4x4 with an auto trans and 205 transfer case. I'm thinking of swapping cabs with one from a 85 2 wheel drive with auto trans. The 74 is a high hump and the 85 is a low hump.
Does anyone know if the hump from the 74 will bolt onto the floor pan of the 85 after cutting out the low section, or can the low hump floor work on the 4x4 without a body lift?
jasons is offline   Reply With Quote
Old 12-08-2010, 07:05 PM   #2
Prerunner1982
Prerunner1982's Avatar
Re: Floor hump? putting 2wd cab on 4x4
You should be able to make the high hump work in the 2wd cab.. otherwise I believe a body lift would be required if you stuck with the low hump.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 12-09-2010, 12:05 AM   #3
Meatman
Meatman's Avatar
Only way low hump would work is with a body lift. I think it was around 80 or so they stopped the bolt in type hump. The 74 would have bolt on hump though, so you could transfer that to the 85 with some modification.
Daily-94 K2500 350 5spd extended cab longbox
Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack.
Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881
My 01 TA and 88 Formula hide in the garage. :-)
Meatman is offline   Reply With Quote
Old 12-09-2010, 01:42 AM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
It will most likely be missing the transfer case hump on the 2wd also.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-09-2010, 03:17 AM   #5
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I have done this before and I had to cut the entire floor hump section from my rusted out cab and weld it in the donor cab. These cabs were 84 and a 85. So I'm sure you'd need to cut out as much of yours as you needed to clear the tcase like mentioned.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-09-2010, 09:09 AM   #6
jasons
jasons's Avatar
Pretty much the answers I expected. Just wanted to make sure before committing to take the 85 cab. I won't have time to do the swap until spring.
Old 12-09-2010, 09:13 AM   #7
thinair
thinair
thinair's Avatar
with the NP205......I'm pretty sure you don't need the high hump.
thinair is offline   Reply With Quote
Old 12-10-2010, 12:21 AM   #8
Meatman
Meatman's Avatar
Im thinking about doing this same thing. 2wd cabs are easier to come by with lots less rust.
