Old 12-08-2010, 08:59 PM   #1
cb1965
cb1965's Avatar
alignment ?s
is there a way to closely allign my front end. i dont want to go to a shop
until i get new wheels on.but i want to be able to drive it on test drives while
im working on it.
p.s. its a 76 suspension and im putting in new tie rods.
cb1965 is offline   Reply With Quote
Old 12-08-2010, 09:14 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: alignment ?s
Unless ur current tires are bad, I would align it, if you take it to Firestone, you can get a 1 time align or a lifetime align, might be worth it if your roads are bad where you live.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-08-2010, 09:35 PM   #3
TR65
TR65's Avatar
Re: alignment ?s
CB,
Check out this thread.
http://67-72chevytrucks.com/vboard/s...ight=alignment
and this one
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 12-08-2010, 11:23 PM   #4
ChopperDr
Re: alignment ?s
I'm assuming the '76 suspension has discs. Here's how I do it: Pull the wheels off and support the a-arms at ride height. Pull a string along the rotor face. The strings can be pulled out in front of the truck so you cam measure between them to set toe. Eyeball the camber and don't worry too much about caster. This method will get it drivable. Its fun to see how close you can get them with this method.
Chop
ChopperDr is offline   Reply With Quote
Old 12-08-2010, 11:44 PM   #5
bama63
bama63's Avatar
Re: alignment ?s
remove the dust cap and use a torpedo level to set the camber and use a tape measure and a friend to measure the toe
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
