Old 12-08-2010, 10:56 PM   #1
2nova2
2003 GMC 2500 4wd HD Issues
Any one have any of these issues?
1. Transfer case chain rub hole in case and makes noise
2. Ignition module come out and get out of sync
3. 4wd doesn't seem to engage
4. Speedo sticks and pegs when going less than speed limits
5. Cruise control doesn't seem to work now, could it be from the above problem
If anyone has had any of these problems let me know what you did to correct.
72 GMC Burb barn door 4X4 350/350 PS PB Tilt ( gone but not forgooten)
64 Chevy II V8 Loaded Wagon
2004 Chevy 2500 HD
Sonoma County, Northern CA
2nova2 is offline   Reply With Quote
Old 12-09-2010, 12:21 AM   #2
bwood
bwood's Avatar
Re: 2003 GMC 2500 4wd HD Issues
#3. If it is the push button 4wd, the switch is a common issue
#4. Yours falls into the age range for the inst cluster service bulliten. Some of the needles go crazy or just quit working all together. GM did a extended warr on these. Check with you local dealer to see if yours falls into it.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 12-09-2010, 12:37 AM   #3
2nova2
Thanks bwood, I bought the truck used so don't think a warranty would apply.
I here there is a solenoid or actuator or what ever its called down under the front that fails as the push buttons sound like they are sending a signal.
2004 Chevy 2500 HD
Old 12-10-2010, 10:06 AM   #4
JohnC
JohnC's Avatar
It doesn't matter if you are not the original owner of the truck for the warranty on the cluster. There is a time frame, and mileage window that you have to be under. I don't remember now what it is. I've had mine fixed twice now!
JohnC is offline   Reply With Quote
Old 12-10-2010, 11:11 AM   #5
2nova2
Would that be considered warranty or recall? How do I find out, call a dealer?
2004 Chevy 2500 HD
Old 12-10-2010, 12:37 PM   #6
truckdude239
truckdude239's Avatar
call the dealer with the mileage and vin number
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-10-2010, 01:35 PM   #7
JohnC
JohnC's Avatar
It's kind of both, but yeah like truckdude said just call your local dealer and talk to them.
Old 12-10-2010, 02:23 PM   #8
2nova2
looks like I am screwed on this one dealer say's to old to many miles, any idea on cost of repair for this?
2004 Chevy 2500 HD
Old 12-10-2010, 07:28 PM   #9
JohnC
JohnC's Avatar
They range in price depending on who repairs it. The first one I had done I went through the dealership, and it cost me about $350. The last time I had it done I found a local guy that did it for about half that. Call around at some of the truck salvage places, or some of the local garages. They may know someone local that can repair the motors for ya.
Old 12-10-2010, 07:32 PM   #10
bwood
bwood's Avatar
Any parts store that handles Dorman Products can get new after market ones also. Don't have a clue on $$$$$$.
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
Old 12-10-2010, 08:37 PM   #11
2nova2
I bought this truck used and it looks beautiful and drives great and through time it has developed these issues I have read about, I paid a lot of money for this truck, 1st the transfer case got the hole warn in it from the pump coming loose at least I think that is what did it and the 4wd dosen't work, not sure if it is the push buttons or solenoid and now the speedo issue, none of these are resolved and I am still driving it. Thinking of buying a older Ford F250 is that wrong?
2004 Chevy 2500 HD
Old 12-11-2010, 12:24 PM   #12
spudz
spudz's Avatar
1. Look for a new t-case. By the time you correct the internal problems with the anti rattle clip that has rubbed a hole, and replace the half case. You can replace it for about the same.
2. Not sure what you mean by gets out of sync. please explain?
3. as for 4wd, its either bad actuator, t-case internal failure, needs updated programing, or needs a switch
4. as for the speedo, you stepper motor is bad, you can buy these motors for about 5 bux. and fix the cluster yourself. Just take it apart, unsolder the motors and resolder new motor. check youtube for instructions. or there are plenty of services that will repair it for you for 75-150.
5. Cruise is probably your brake switch... but who knows.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 12-11-2010, 12:25 PM   #13
spudz
spudz's Avatar
its called a special policy
Old 12-11-2010, 12:27 PM   #14
spudz
spudz's Avatar
btw if you keep driving it with no fluid in the t-case.... it WILL lock up or explode.
Old 12-11-2010, 12:59 PM   #15
2nova2
Spudz Re
My wife drove my truck one day and called me from her destination and said that the key just spins so I thought I would do a google search before a went to look at the trucks problem, I found some info stating that there is a module that clicks in the botton of the key switch, once I removed the plastic housing from the steering column I found this module and it seemed it was not clicked in and maybe it popped out allowing the key cylinder to spin, it may have came loose because of the tilt wheel getting slammed by accident from time to time. So this info I found said the module had to be synced (Indexed) up with the tumbler and after clicking the module in I saw what they meant as the ignition wouldn't work correctly and if you got it close enough to work it could still be one click off where you could get a power source drain, in my case it was the trans selector light and it stayed on after I turned the key off, so I pulled the module back out and turned the key slightly to index the module till I found the right place and for now seems to be working correct. Sorry for the long explanation.
Jim
2004 Chevy 2500 HD
Old 12-11-2010, 01:27 PM   #16
2nova2
I patched the hole and it has oil but still makes a rattle sound. So at this time could it be fixed or should I replace and If I replace whats going to keep it from doing it again?
2004 Chevy 2500 HD
Old 12-11-2010, 01:33 PM   #17
2nova2
The dealer gave me a 800 number to call and they said 70,000 warranty or so many years, my truck 144,000
2004 Chevy 2500 HD
Old 12-11-2010, 03:26 PM   #18
spudz
spudz's Avatar
I have had limited success with jb weld. it is prolonging the inevitable...
what has happened is the anti rattle clip has broken, and rubbed a hole in the case. the best thing to do it find a used half case. BUT if you want to prevent/correct the problem.... go here. this will explain what has happened.
http://www.merchant-automotive.com/tech/tcp.pdf
Old 12-11-2010, 03:29 PM   #19
spudz
spudz's Avatar
here is the upgrade kit... I REALLY need to do this to my 04 z71..
http://www.merchant-automotive.com/t...grade-kit.aspx
Old 12-11-2010, 03:59 PM   #20
structures
structures's Avatar
I had to go outside and check my t case. It was dry on the tail. I have an 03 Z71 with 75,000 miles.
Is there a warning sign I can look for prior to the pump housing wearing thru the t case housing? Maybe some of the loud rattling 2nova2 is talking about? Or is it fairly silent until it wears thru?
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 12-11-2010, 05:55 PM   #21
spudz
spudz's Avatar
some never rattle. they just get a hole and leak
Old 12-13-2010, 08:09 PM   #22
2nova2
Thanks for the link, I will going to do that.
2004 Chevy 2500 HD
