Old 12-08-2010, 11:06 PM   #1
JRE
Newbie has a brake question
I'm buying a real nice 67 1/2 ton long box that has power drum brakes. What brake parts can I keep when I change it to disk brakes. Plan on using Dropped A arms and springs to lower the front 5 inches.
JRE is offline   Reply With Quote
Old 12-09-2010, 11:19 PM   #2
JRE
Re: Newbie has a brake question
Anybody know where I might be able to find the answer.
Old 12-10-2010, 01:10 AM   #3
geezer#99
geezer#99's Avatar
Keep your booster. You'll need a new disc/drum master cylinder and proportioning valve. Your brake lines should be good as well as the rear brakes.
Old 12-10-2010, 02:18 AM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Originally Posted by geezer#99 View Post
keep your booster. You'll need a new disc/drum master cylinder and proportioning valve. Your brake lines should be good as well as the rear brakes.
x2
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-10-2010, 10:37 PM   #5
JRE
Thanks.Thats what I was thinking just wanted to make sure I wasn't missing something.
