I'ma yearnin for some learnin!
tubular control arms 67-72
Pics and opinions please.
Thomas
1968 Chevy C10 Shortbed Stepside ![]() |
Re: tubular control arms 67-72
Price, fit, finish, Portrbuilt.
/thread.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
Not bad, any pics with them on?
67-72 parts collector,…
![]() Join Date: Nov 2002
Porterbuilt would be my first choice!
http://porterbuiltstreetrods.com/sit...rting-at-1099/ Are you wanting them for bags or coils springs?
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-09-2010 at 01:26 PM. |
Bags? Porterbuilt.
Coils? Hotchkis.
bags eventually
Kieth is everything there bold on or did you have to mod?
Thomas
That pic is a full dropmember setup, but it isn't required to run the arms. Just use the correct ball joint for your spindle.
#9 | |
(www.PorterbuiltStreetRods.com) They build just about any a-arms you would want. Stock, narrowed, for all C10 trucks, 1/2 ton thru 1-ton. Like previously mentioned,... that picture is attached to a Dropmember, to allow the front to lay out. Their a-arms can be bolted to stock front crossmembers also.
