Old 12-09-2010, 02:46 AM   #1
Dru
1 ton dually/single wheel front rotor swap?
Hello all,
Typed out a bunch of stuff explaining why I'm at this point, but that might be better saved for the actual swap.
I tried to find all the info I could through the search, and also tried to use O'reillys online store to compare spindle part numbers, but they didn't seem to have them listed.
Does anyone happen to know if I can bolt single wheel rotors to the dually rotor spindles in the pic below?
Also if I can, would I be stuck with mudder type wheels that stick out past the body, or can I get a wheel inside the fender, and have a little dish to it still?
Trying to figure out some options I may have, any info is much appreciated, thank you.
Edit: Just to add..I do not want to swap out the spindles really, they are almost new, but a little rusty Belltech dropped units.
Dru is offline   Reply With Quote
