Old 12-09-2010, 09:06 AM   #1
shermro99
Unhappy Doors Won't Lock
Passenger door wont lock and close if being pushed from the outside. Once it is shut it will only lock from the inside.
Driver door wont lock at all.... what might be the culprit?
1970 Chevy C-10 P/U with original doors
Thank you!
shermro99 is offline   Reply With Quote
Old 12-09-2010, 09:17 AM   #2
nutsforchevys
nutsforchevys's Avatar
Re: Doors Won't Lock
I have to lock mine from the outside with the key after shuting the door. I thought they were made that way.??
72 Super Cheyenne lwb 4X4 Ocra / White
88 Chevy 1 ton Dumptruck
88 Chevy 1ton Flat bed 4X4 white
nutsforchevys is offline   Reply With Quote
Old 12-09-2010, 11:53 AM   #3
MVHandy
Nuts is right, you can't push down the lock and close the door. The good news is that you can't lock your keys inside. On mine I have a problem locking one door with the key but not unlocking. It's usually wear and misalignment, these are 40 year old machines.
While replacing window channels I played around, there is a spot worn down on the latch mechanism so the things don't line up perfectly, i put a shim in to test my thory and that was it so it looks like a new latch needed or I could try to do a little weld build up on that part of latch.
MVHandy is offline   Reply With Quote
Old 12-09-2010, 12:44 PM   #4
shermro99
Talking Re: Doors Won't Lock
ah! Now that makes sense. Thank you. Thought I was going crazy
