Old 12-09-2010, 12:52 PM   #1
StevieC
Primer color
if you're gonna leave your truck primered for a while... what color do you choose?
StevieC is offline   Reply With Quote
Old 12-09-2010, 12:56 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Primer color
If it were me, I would use a black primer.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-09-2010, 12:59 PM   #3
StevieC
Re: Primer color
I saw one yesterday that looked like dark dark bronze or brown.... almost black
looked good
Old 12-09-2010, 01:00 PM   #4
timjt
Re: Primer color
Dark grey, probly what I'll be doing for the winter till I can get it done correctly
2001 silverado stolen by family
1983 short n wide custom deluxe SOLD
1985 silverado longbed 305 engine 700r4
OH NO! NOT ANOTHER LEARNING EXPERIENCE!!!
"Just because you can do it, doesn't mean that you should"
timjt is offline   Reply With Quote
Old 12-09-2010, 01:10 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Primer color
I would choose the color primer that is closest to what you want to apply for finish paint. For example if the truck is going to be white, use light gray. If the truck is going to be a dark color, pick a dark gray or black primer.
Just note most primers are porous and will allow rust to form if left to weather. The best primer as a base for just about any paint is epoxy, which seals the metal and also makes a great base for body filler.
Old 12-09-2010, 01:25 PM   #6
StevieC
Re: Primer color
what about satin black?
or is that too hard to sand later?
Old 12-09-2010, 01:26 PM   #7
StevieC
Re: Primer color
oh and I'm thinking orange, red, or teal for the final color
Old 12-09-2010, 01:44 PM   #8
TwoFiftyShifter
Re: Primer color
If I was going with one of those colors I would use grey primer.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 12-09-2010, 01:58 PM   #9
jchav62
1962 C-10
jchav62's Avatar
Re: Primer color
My buddy's Dad has an old Ford truck. They were able to 'dye' the primer to an almost torquoise color, which was original for that truck. Looks good! I believe they were able to dye it at the paint shop.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 12-09-2010, 02:12 PM   #10
1/2Dozen
1/2Dozen's Avatar
Re: Primer color
definitely use Epoxy to seal up metal from moisture and color choice would be gray considering your final color choices.
66 suburban
51 Merc 2 door coupe
38 Chevy Business Coupe (gf's)
76 Airstream Sovereign
1/2Dozen is offline   Reply With Quote
Old 12-09-2010, 04:28 PM   #11
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: Primer color
You can buy a primer ( many companys make it so pick your flavor and go from there) that you can mix both ways one is a primer only ( easier to sand) the other way it is a true sealer ( will take more elbow grease when you block it) Iused it on my truck for the insides of areas that I will not be painting and you will never see anyways.
Standard primer will rust ... only making more work later.
GMR-PERFORMANCE is offline   Reply With Quote
Old 12-09-2010, 08:32 PM   #12
ol_skool_chevy
ol_skool_chevy's Avatar
Re: Primer color
Normally I would say that dark brown Primer if I was going to drive it but after trying to block sand it I would not use it again....it clogs sand paper pretty bad and just seems to not work as well as Grey...so I would use Grey
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 12-09-2010, 09:00 PM   #13
onequickchevy
onequickchevy's Avatar
Re: Primer color
If you are leaving it primer and it will see any weather, use a 2K urethane primer. It seals well and is tintable to your color. If you are on a tigh budget (and who isn't these days) don't be afraid of the store brand. We use alot of Parts Master primers now in our hobby shop. Also, please note that all laquer based primers will allow moisture to pass and will rust under the primer. Alot of people think that the red primer doesn't allow this to happen, but it does. The rust just happens to match the color of the primer.
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
