Old 12-09-2010, 10:24 PM   #1
71rustpile
71rustpile's Avatar
Power steering gear box
I'm in the process of converting my 4wd Blazer to 2wd. Does anyone know if I can use the 4wd steering box with a 67-72 2wd steering setup. I was thinking I could just change out the pitman arm and it would work but I looked in the LMC catalog and there are separate part #s for 2wd and 4wd. Anyone..................?
Dan
71rustpile is offline   Reply With Quote
Old 12-10-2010, 07:09 AM   #2
Blazer1970
Blazer1970's Avatar
Re: Power steering gear box
The output shafts in the boxes are keyed differently.
Blazer1970 is offline   Reply With Quote
Old 12-10-2010, 10:26 AM   #3
Burt4x4
Burt4x4's Avatar
Yup, they are different.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 12-10-2010, 03:31 PM   #4
dnandez
dnandez's Avatar
I just went through that. I actually used a front end out of a 77 c10. I pulled it out at a u pull it for 80 bucks and got the steering gear box and all. Good luck.
72' K5 Blazer
71' K5 2wd conversion project 454 ls7
71' C10 Cheyenne long box 66k original miles
dnandez is offline   Reply With Quote
