Old 12-09-2010, 11:58 PM   #1
up north
Front seal on transmission
Hey all,
I am just about ready to install a rebuilt engine in my "98 suburban. I have been told that before I do this I should replace the front seal on my transmission just behind the torque converter.
Any opinions on this? is this something that normally gets done when you pull an engine? The seal wasnt leakiing before.
THanks again for your help
Doug
up north is offline   Reply With Quote
Old 12-10-2010, 07:28 AM   #2
Zeke
Active Member
Re: Front seal on transmission
It's really a craps shoot and depends on how many miles are on it, reasoning is since it is apart put a new seal in and it should last as long if not longer than the one in there now which may or may not start leaking. When you pull an engine you push the torque converter back towards the transmission which may damage the seal lip. I changed the flex plate on mine, didn't change the seal and it doesn't leak...if it starts leaking I will have to pull it all apart again.
Since it is apart you can change it for peace of mind, put a high quality seal in it.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 12-10-2010, 11:58 AM   #3
up north
Is this a pretty difficult job? Does the torque converter just slide off and then expose the seal?
Thanks for your replies
Doug
Old 12-10-2010, 12:02 PM   #4
timjt
If its anything like an 85 it would be pretty easy but thats over 10 years difference.
2001 silverado stolen by family
1983 short n wide custom deluxe SOLD
1985 silverado longbed 305 engine 700r4
OH NO! NOT ANOTHER LEARNING EXPERIENCE!!!
"Just because you can do it, doesn't mean that you should"
timjt is offline   Reply With Quote
Old 12-10-2010, 04:18 PM   #5
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
it is very easy to do.....
some people do it.. some don't....
i have done it both ways......
tommie is offline   Reply With Quote
Old 12-10-2010, 06:00 PM   #6
Zeke
Active Member
It just slides off and on. It's heavier than it looks so just be ready. When putting it on make sure you engage the torque converter into the pump, just pull out a little turn and push back in. If you have never done this before the converter push it all the way back to the trans before you pull it off so will know what it looks like when the converter is installed and engaged with the pump.
1969 C10 350 3spd
Old 12-11-2010, 09:58 PM   #7
cparman
sharp as a marble
ZEKE is correct. BEFORE you pull the converter look closely to how far into the trans the converter is. If you do not get it all the way in after the front seal install, you can damage the front pump.
cparman is offline   Reply With Quote
