6 lug wheels question/needing pics!!!
I know that there are several post on her reference to 6 lug wheels. My question is though, I am running ECE 4.5/6 drop with their 6 lug disk setup. Does any one know if a set of stock 1970 steel wheels will fit. If so could any one post some pics? I am building a driver and don't wont to spend a ton of money on a new set of wheels. I have a set of steel wagon spokes but they are not very appealing to me! Thanks Guys and Gals!
Re: 6 lug wheels question/needing pics!!!
Give the guys at ECE a quick call...if I remember correctly the stock wheels will not work with the new parts...calipers hit the wheel?? I have the same on my truck..4/5 1/2 ECE...running Wheel Vintiques wheels..hope this helps
I have a 6 lug conversion on mine. Using stock 15x6 on front and 8's on the rear. I have heard that there are 2 different styles of stock steel wheels. One that fits with disc and one that doesn't. Mine were the right ones luckily.
Brett |
67-72 parts collector,…
![]() Join Date: Nov 2002
The pre-'71 wheels won't work with the disc brakes.
You need the '73-87 stock steel wheels that were originally intended for the 1/2-ton 4x4 trucks with hubcaps.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-10-2010 at 07:25 AM. |
This should be the difference in the wheels
'69 short step with dreams of being a hot rod You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. |
![]() Join Date: Oct 2009
What size tires are you running?
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
They are 225/70 in front and 275/60 in the rear.
Brett |
If you are asking about 15" 6 lug wheels, they must be 71 or later in order to clear the calipers. So basically this means wheels from 71-87 4WD trucks.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
