Retired Air Force Veteran
![]() Join Date: Aug 2007
stock radio install/mounted
When installing/mounting a stock radio, where does the rear bracket attach to the under dash? any pics?
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 12-10-2010 at 09:46 AM. |
Re: stock radio install/mounted
I belive there are some indents where each screw gowes in the fire wall behind and just above the stock radio. My truck never came with a radio and it has the indents for the screws, my truck is a 1968 model.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 12-10-2010 at 10:44 AM. |
Thanks, I'm taking the "hacked" dash front out today sometime and will look before I reinstall the new front.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
![]() Join Date: Oct 2010
the radio has a bracket on the back that a metal strap runs up and down off of. The metal strap connects to the back of the radio then runs up to the speaker where it attaches to the speaker bracket. The speaker bracket hooks up to the firewall. The radio doesn't screw into the firewall. It is held in the dash by the cups under the knobs then gets further support from the metal strap that hooks up to the speaker. There was a thread about a month ago that showed the setup I'll see if I can find it. I recently hooked an original am radio up in mine and had to search everywhere to get the right brackets and cups under the knobs. Once I got all the right stuff (ebay, parts board) the radio hooked up solid. No vibration at all.
i have the cups and the flat nuts. thanks for the info
here's a pic
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
thanks for the pictures
