Old 12-10-2010, 11:32 AM   #1
Morris315
Morris315's Avatar
Lowering without cutting the bed?
Hello guys, I'm wanting to lower the rear of my truck (65Chevy 3/4 ton) but I don’t want to cut the bed. Also my plain is to be able to haul a trailer with it so I'm going to put air bags in the back and do a small notch. I want to have it sit low and still have some good travel. I would like it to sit like it dose now but with more travle room. Lets see some picture if you got'em and tell me what suspension your running, thanks.
Morris315 is offline   Reply With Quote
Old 12-10-2010, 12:10 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Lowering without cutting the bed?
I ended up raising the bed floor about an inch so that I didn't have to cut a hole in the middle of the bed to allow the rearend housing pumpkin from coming up through the floor. I am also running air springs. If you are going tow, I would really consider one of the heavy duty C-notch kits.
Here is a photo of what the rear of my chassis looks like (I do not have the HD C-notch)...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-10-2010, 01:27 PM   #3
Morris315
Morris315's Avatar
http://67-72chevytrucks.com/vboard/s...ght=notch:jdp:
This link opened my eyes! Not doing a notch. Would like to see some trucks without notches that have been lowered and baged, thanks guys.
Old 12-10-2010, 01:40 PM   #4
jimmydean
jimmydean's Avatar
When I first bagged my '69, I didn't cut the frame and used a short cup to route the air line. The front has uncut Suicide Doors cups and drop spindles with Slam Specialties bags.
It was pretty low, but not crazy. I could have gotten the rear lower with some blocks, too.
From the front
Some articulation
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-10-2010, 01:54 PM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Mine is lowered without a notch. The rear springs were cut and the tortions on the front lowered. The front was lower that this picture shows. It was riding on the bumpstops and was killing me.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-10-2010, 02:04 PM   #6
Allensracing
Allensracing's Avatar
I think the rule of thumb is that if you want suspension travel and a c-notch, you better plan on cutting at least a center notch in the bed. you might get away with a 2 inch c-notch and not touch the bed. just make sure the bumpstops are relocated to prevent the pumpkin from coming through
Allensracing is offline   Reply With Quote
Old 12-10-2010, 02:59 PM   #7
Morris315
Morris315's Avatar
JIMMYDEAN- Your truck looks great! Im sure the pics are shown with the bags all the way down right?
Old 12-10-2010, 04:26 PM   #8
jimmydean
jimmydean's Avatar
Yes, that was dumped. Here is the same shot at full lift.
Thanks, I miss that truck, but my '66 will be better in the end.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
lowering, not cutting bed
