Old 12-10-2010, 02:44 PM   #1
68gmcc10
instrument panel conversion
hi i ran in to a problem my truck came with just the 3 gauge instrument panel i wanted to convert it the 7 hole instrument panel the one that hs the temp oil pressure and etc but my question is do i have to change the dash harness or will it just plug up i have a 67 c10
68gmcc10 is offline   Reply With Quote
Old 12-10-2010, 03:19 PM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: instrument panel conversion
Here is a thread from GMC Pauls (A Vendor) Click on the link and scroll down and you'll see the color coding for both clusters
http://www.gmcpauls.com/Tech%2520Tips1.htm
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 12-10-2010, 03:45 PM   #3
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Requires repinning the harness, you can pull the pins out with a thin screwdriver and then reinsert them as shown on Paul's page as mentioned above
If you get a chance to grab the connector for the 7 gauge dash, do so. YOu might need a few extra pins - I needed two, as I recall
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 12-10-2010, 03:50 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You will also have to add two wires for the Battery Gauge since the 3 gauge only has an idiot light, and you will have to re-wire the idiot light wire in order for the alternator to charge.
You might want to start a new thread over in the electrical forum when you get into the swap, since this one will be on the second page by the end of the day and very few will see it.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-10-2010, 04:22 PM   #5
natechevy72
natechevy72's Avatar
I'm glad you asked, This is something I was needing to know also.
natechevy72 is offline   Reply With Quote
