Converting my 4X4 to vette IFS and IRS??
So ive been searching all over the forum about converting from 4x4 to 2wd, and have found a lot of helpful information, but it seems that everyone is converting to stock 2wd front setup. I have both the front and rear setup from an 80s corvette, and am trying to figure out if its gonna be major surgery or a semi basic swap. Im not too worried about the rear end, but the front end stuff is what im worried about. Is there a kit that locates the upper and lower a-arms or will I have to fab it up? I really dont want to do a totally fabbed front crossmember, and am hoping there is a kit that would weld onto the outer part of the frame rail. I think the rack and pinion would be a way better than the stock steering box. Also I have a new 700r4 with the transfer case on the back, would it be easy to put the 2wd tailshaft on and get a 2wd driveshaft? what do you guys think?? I would run it with a coilover setup so I could adjust my rideheight and play with shock dampness. Any imput on this would be super helpful
Eric
