Old 12-10-2010, 07:34 PM   #1
71sierragrande
Petroleum User
71sierragrande's Avatar
Play in the wheel; loose steering on '71 Sierra
Ive got lots of play in the steering, which I thought might be worn pittman/idler arms. A guy told me it's just an adjustment in the steering box. Is he right? If so, what do I have to adjust? I've never done it before. Thanks
71sierragrande is offline   Reply With Quote
Old 12-10-2010, 08:01 PM   #2
cdowns
cdowns's Avatar
Re: Play in the wheel; loose steering on '71 Sierra
adjusting a box is chancy at best should b a last resort// pitman idler tierod ends balljoints ragjoint aframe bushings should all b checked first
Old 12-10-2010, 09:01 PM   #3
71sierragrande
Petroleum User
Thanks, I thought so. Do you know if those aftermarket steering stabilizer kits (LMC) make any improvement at all?
Old 12-11-2010, 02:18 AM   #4
swamp rat
swamp rat's Avatar
Disclamer: If you were to do the following while the steering wheel is straight then the steering can and probably will bind when turning due to the wear on the gears, got it? then read on.
If you want to check the steering box then pop the hood and look down at the top of it and you'll see an allen type set screw with a loc nut ( don't recall the sizes) Now due to the wear which is normal on a steering gear turn the steerring wheel all the way to one side then loosen the loc nut and see if you can turn that allen screw down a little to lightly contact the steering gear inside, then lock the loc nut, when the loc nut is tight the allen should bairly make any contact at all. Now turn it to the other side and make sure it does not feel like it has gotten sticky when at a full turn to ether side. thats all there is to it and it only takes a few minutes and cost nothing. I agree tho that more gains will be had by checking and or replacing other steering components
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-11-2010, 02:30 AM   #5
Allensracing
Allensracing's Avatar
the steering box adjuster is commonly obscured with caked on grime if its a daily driver.
you might have to chip away at the buildup to find it.
Allensracing is offline   Reply With Quote
Old 12-11-2010, 09:55 AM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
x2
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 12-11-2010, 10:10 AM   #7
bignbad
bignbad's Avatar
the box might be wornout.I had the same issue with mine the box was worn.I replaced it.
easy swap about an hour if i recall
'72 chevy k20
'06 H-D Springer softail
http://www.bluemooncruisers.com/
http://www.enginecycle.com/
~Eric
bignbad is offline   Reply With Quote
Old 12-13-2010, 12:43 PM   #8
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
There are two adjustments; the one mentioned above and then there is also a preload on the shaft gear itself, which requires a special spanner. Not a good thing to monkey with - I had a box that was adjusted (by the factory - new AGR performance box) incorrectly fail and lock up hard left on me - not good!
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 12-13-2010, 03:47 PM   #9
raycow
If you are going to play with the adjuster on the steering gearbox, it MUST be done with the box at the exact center of travel. That's where the "high" spot is on the gear. If you do it with the box turned to either side you can damage the gear when you turn it back to center. Trust me on this.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-13-2010, 03:55 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Another warning on adjusting the box.... try very small adjustments, and if you go just a bit too far, it will not return to center without help. Get it right and you'll just buy a little time -- the box will need to be replaced soon anyway.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-13-2010, 08:47 PM   #11
swamp rat
swamp rat's Avatar
Ray
Raycow, i'm not trying to give bad advice, but every time i have adjusted the box in the middle it would bind up when at a full turn, what i was taught is the gears recive the most wear where they are used most thus more slop in the steering, meaning in the center poisition going straight down the road or close to it for turning have more wear than at full turn.
Can you explaine to me more about this high spot? Thanks.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 12-13-2010, 09:07 PM   #12
leddzepp
Moderator
leddzepp's Avatar
Here is your answer. I completely rebuilt my front end replacing everything and got new tires and an alignment. Still had slop. Replaced the steering box, now it is like a NEW truck. 40 yr old boxes are shot, do yourself a favor and replace it. Brakes and steering are the 2 most important things on any vehicle.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 12-15-2010, 04:55 PM   #13
71sierragrande
Petroleum User
Thanks for all the input fellas, lots of great info. I probably will just order a new box. U guys are right, it will need to be replaced soon anyway and might as well get it out of the way.
Old 12-15-2010, 06:52 PM   #14
FL71C10
Where did you get the box, and what kind did you get?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 12-21-2010, 12:58 AM   #15
dfwright
dfwright's Avatar
I've been following your build, and I remember you originally replaced some seals on the original power steering unit. I just looked at your build again and didn't see reference to the new PS box. What did you end up buying?
I have been planning to rebuild mine, but now I'm wondering....
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 02-15-2011, 12:54 AM   #16
derekb
derekb's Avatar
Just bumping it back up as I am looking into the same issue with mine and I'd like to know where you got the new box from.
derekb is offline   Reply With Quote
Old 02-15-2011, 07:51 AM   #17
Adding that steering stabilizer from LMC might help a truck with all wear parts in tip=top shape. it would be a band aid on anything else. The solution is to replace worn steering parts. Most cost less than the steering stabilizer.
