Old 12-10-2010, 11:53 PM   #1
Tagar89
I'ma yearnin for some learnin!
Tagar89's Avatar
What would happen if i mixed up my spindles?
Like if i put the left on the right and the right on the left?
Thomas
1968 Chevy C10 Shortbed Stepside
Tagar89 is offline   Reply With Quote
Old 12-11-2010, 12:01 AM   #2
darthwall
Re: What would happen if i mixed up my spindles?
your wheels end up sitting farther back it makes turning harder and wear tires alot faster probably hit inner fenders it's no good
darthwall is offline   Reply With Quote
Old 12-11-2010, 12:03 AM   #3
Tagar89
Tagar89's Avatar
so the caster would be off. How can i tell between the sides?
Old 12-11-2010, 12:14 AM   #4
darthwall
the arms will kinda slope back looking from where the engine is. front of the truck arms angled back. back of the arms will look straight if this helps
Old 12-11-2010, 12:20 AM   #5
Tagar89
Tagar89's Avatar
Will my tie rodds hook upalright? Could you tell from a pic. I took apart my front suspension re doing it and forgot to mark them
Old 12-11-2010, 12:23 AM   #6
69 longhorn
Thomas
It wont work, it would put your steer linkage BEHIND the crossmember instead of in front... crazyAl
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 12-11-2010, 12:27 AM   #7
darthwall
post up a pic from the top and the front
Old 12-11-2010, 12:31 AM   #8
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
....unless they were reversed and upside down?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-11-2010, 12:36 AM   #9
69 longhorn
Amen brother! If he is talking the top A arms, yes they can be mixed up Upside down on the spindles would also cause some serouis ball joint issues... crazy Al
Old 12-11-2010, 12:36 AM   #10
lilpoindexter
lilpoindexter's Avatar
But the taper on the spindles wouldn't match the tie rods
lilpoindexter is offline   Reply With Quote
Old 12-11-2010, 12:41 AM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Brake caliper bolt on the top,... behind the centerline of the spindle.
Make sure you get the steering centerlink and tie rods assembled correctly, also.
Keith
Convert to disc brakes.
Old 12-11-2010, 12:55 AM   #12
Tagar89
Tagar89's Avatar
****ty pic, idk if it helps.
Old 12-11-2010, 12:56 AM   #13
Tagar89
Tagar89's Avatar
Thats the passanger side, i cant take anymore pics because its at school.
Old 12-11-2010, 12:59 AM   #14
69 longhorn
Thomas
Post a pic if you can.....I think we have a couple "clowns " playin Me included There is no way in he!! that you can swap the spindles side to side & make the linkage hook up. If you swapped the top a arms side for side, you will run into the problem that darthwall mentioned...a pic is worth 1000 words, & we will help crazyAl
Old 12-11-2010, 01:03 AM   #15
Tagar89
Tagar89's Avatar
Look up bro
Old 12-11-2010, 01:08 AM   #16
darthwall
switch sides out thats the wrong way
Old 12-11-2010, 01:09 AM   #17
69 longhorn
Where is the steering knuckle? Not on yet, or is it facing rear?
Old 12-11-2010, 01:12 AM   #18
Tagar89
Tagar89's Avatar
ITs not on yet
Old 12-11-2010, 01:14 AM   #19
Tagar89
Tagar89's Avatar
ITs on as of now, along with a couple other things but this is the most recent pic. I noticed from a previous pic that i had the steering knuckle upside down. If you cant tell from the pic or asking me questions dont worry about it. I might go to school early tomorrow or monday to update the pic. Just tell me what you want a pic of
Old 12-11-2010, 01:16 AM   #20
69 longhorn
Its been a while since I played with drum brakes, but I think that knuckle only bolts on 1 way. check your pcs, the knuckle needs to be foward, to hook all the steer linkage.
Old 12-11-2010, 01:20 AM   #21
Tagar89
Tagar89's Avatar
ok what i did when it comes to the knuckle was put the other side on, there for the round part went around the tie rod bolt. But form looking at this pic i noticed i did it all wrong.
But im still a little worried about the spindle
Old 12-11-2010, 01:38 AM   #22
darthwall
good catch I didn't understand completely the question
Old 12-11-2010, 02:03 AM   #23
Tagar89
Tagar89's Avatar
All in all if i get it wrong it will show up of the 30k$ alignment machine we have at school lol, i just dont want to go back and correct it
Old 12-11-2010, 10:10 AM   #24
LONGHAIR
Tagar89,
For future reference, it helps a lot to give more information in the first place.
If you had stated the year, model, drum brakes, etc... Many of these questions would never have happened, and you would have gotten more pertinent responses much quicker.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-13-2010, 02:34 PM   #25
Tagar89
Tagar89's Avatar
I apologize, it totally went over my head that this was for other trucks besides 67-72. Sorry guys
Thomas
