Old 12-11-2010, 10:52 AM   #1
cochino12
It followed me home?
cochino12's Avatar
Front end noise, wheel is loose
While driving the other day I started hearing a banging coming from the passenger front tire area. If I pull on top or side of the wheel there is just enough play to cause some noise. I assume it's a bad ball joint but what else should I be looking/checking? Also, is it safe to drive until I have some time to fix it next week? Thanks for any help
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-11-2010, 11:27 AM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Front end noise, wheel is loose
Which truck is it on? I had the drag link go bad on my one ton, it made a lot of racket.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 12-11-2010, 11:49 AM   #3
cochino12
cochino12's Avatar
I guess that might be good info haha, it on my 88 1 ton. A bad drag link wouldn't cause the wheel to feel loose though would it?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-11-2010, 11:57 AM   #4
Dalaigh
Canadian Trucker
Dalaigh's Avatar
My guess would be a wheel bearing if you able to move the tire top and bottom aswell as side to side. And if its only happening to one side of the truck.
Dalaigh is offline   Reply With Quote
Old 12-11-2010, 12:00 PM   #5
babyJay
babyJay's Avatar
Yes, I could wiggle it side to side, but I didn't try up and down.
Jason
89 R3500 CC SRW
Old 12-11-2010, 12:09 PM   #6
cochino12
cochino12's Avatar
How do I check that? Also, is it ok to drive for a short time?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-11-2010, 12:30 PM   #7
spudz
spudz's Avatar
nobody can tell you if its ok... It may last for 100 years and your wheel may fall off pulling out the driveway.. IF you are in dout. I wouldnt take the risk.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 12-11-2010, 12:47 PM   #8
Dalaigh
Canadian Trucker
Dalaigh's Avatar
The best way to check is take the wheel off, and try to move the brake disc the same way you moved the wheel, if the brake disc moves and nothing else its likely the bearing. That way if it's not the bearing you can see how the rest of the suspension is reacting.
And I agree with Spudz, I wouldn't use the truck till you can fix it.
Old 12-11-2010, 09:55 PM   #9
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i had a wheelbearing go once while on the highway and the heat caused the whole spindle to crack in half right up behind where the outer wheel hearing toasted.... it is NOT SAFE to drive anywhere
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-11-2010, 10:28 PM   #10
3r!c84
Badass
3r!c84's Avatar
drive it till the wheels fall off... well not literary
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-12-2010, 12:30 AM   #11
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Replacing wheel bearings (which is what sounds like the issue to me) is way cheaper than the damage that can follow from it going out completely. I had one go bad in a VW I used to have.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 12-12-2010, 01:18 AM   #12
f.monroe
f.monroe's Avatar
Adam,
You need to place a floor jack under the lower control arm and jack the truck up . This will take the load off of the ball joints,upper A-frame bushings,etc. Move the wheel in and out and left and right . You will be able to find the problem this way . It is hard to troubleshoot with the weight of the vehicle masking the slop in balljoints or bushings.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 12-19-2010, 09:38 PM   #13
cochino12
cochino12's Avatar
Ok so I finally had some time to look at this thing today. Turns out the spindle nut was loose and that was it . Anyway, Im up and running again now, just waiting til after the holidays and I think I'll list it on ebay. If it doesnt sell by the end of January I'm going to keep it.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-20-2010, 08:48 PM   #14
spudz
spudz's Avatar
Trust me... you needed to repack the wheel bearings.
Old 12-20-2010, 09:17 PM   #15
babyJay
babyJay's Avatar
Glad you got it fixed, and saw it in the FS section. That could have turned out to be hair raising scary!
Jason
89 R3500 CC SRW
