Old 12-11-2010, 11:17 AM   #1
eyebuzz
Licensed driver
eyebuzz's Avatar
Alternator Q
72 350 - battery died, got it jumped to start - on the way home turn signals, light all out or dim...I'm guessing it's my alternator...couple of Qs:
1) The back say Delco Remy (made in America) - This looks to have the voltage regulator as part of it as I see no external one...am I right here (see photo).
2) I only have one red wire coming off the back - assuming this has an internal voltage regulator - is this set up still correct? (ie. should there be other grounds or such?)
I ask cause, Autozone has two alternators - one with external VR and one internal.
Thanks, TT
eyebuzz is offline   Reply With Quote
Old 12-11-2010, 11:26 AM   #2
hayhauler71
hayhauler71's Avatar
Re: Alternator Q
The green wire is for the coolant temp sender that is mounted in the cylinder head. That looks to be a one wire alternator and looks to be wired correct and yes it has a internal regulator.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 12-11-2010, 12:01 PM   #3
eyebuzz
Licensed driver
eyebuzz's Avatar
Re: Alternator Q
Thanks Hayhauler - off the parts store. Best, TT
Old 12-11-2010, 12:51 PM   #4
Allensracing
Allensracing's Avatar
Re: Alternator Q
somewhere on the alternator is a two prong connector. if there is nothing plugged into it, you have a "one wire" alternator. you need to make sure the replacement is also a one-wire.
a picture of the back of the alternator would give more info
Allensracing is offline   Reply With Quote
Old 12-11-2010, 01:52 PM   #5
cdowns
cdowns's Avatar
Re: Alternator Q
i'd try cleaning up both battery cables b4 buying an altenator
