Old 12-11-2010, 09:12 PM   #1
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Ball Joint Covers...Inside & through hole????
Hi,
question about ball joints....do I push the grease cover through the hole and then press the ball joint into the hole (and risk cutting the grease cover as I did already)??
Or do I take the cover off, press the 'naked' ball joint into the hole, then push the grease cover on the shaft and the spindle holds the grease cover in place???
THANKS!!!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 12-11-2010, 09:25 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Ball Joint Covers...Inside & through hole????
Naked ball joint is inserted first. The cover goes on afterwards!
LOL, I've never seen anyone do that before!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 12-11-2010, 09:26 PM   #3
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
x2 made this mistake myself once
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 12-11-2010, 11:51 PM   #4
Gordonr1973
Home Built '87
The upper ball joints would be the same way then too?
I never have replaced any before so I didn't know.
Is it worth it to get the more expensive 'name brand' ball joints or are jobbers okay?
Gordon
Old 12-12-2010, 12:24 AM   #5
gchemist
gchemist's Avatar
The top goes on the same way. I think it may actually have room to go with the boot on. The top joint is bolted to the arm. The lower one is pressed in.
I like using Moog ball joints.
Old 12-12-2010, 12:37 AM   #6
benoit454
Chris
benoit454's Avatar
we bought the cheapest ones they had listed at rockauto. We also used cheapies from autozone years ago on a 76 no issues. The top has enough room to put the boot on and slide it in place, but you can stick it on after it's in the arm.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 01-09-2011, 05:22 PM   #7
Ynotnow817
Ynotnow817's Avatar
I know the ball joints are greased when I bought them, but do I add more grease before I put on the spindles Or after or do I not need to add more grease?
Ynotnow817 is offline   Reply With Quote
Old 01-09-2011, 05:43 PM   #8
benoit454
Chris
benoit454's Avatar
I'd wait until everything is back together then grease them, DEFINATELY ADD MORE GREASE! They only have enough on them to keep out rust it seems like. I'd grease them until you start to feel the rubber boot/cover swell then stop. We just did a whole front end on the 84 back in No.v and greased everything after it was done.
Chris
GIT R DONE!!!!!!
Old 01-09-2011, 06:07 PM   #9
Ynotnow817
Ynotnow817's Avatar
Awesome, thanks
Old 01-10-2011, 08:53 PM   #10
gchemist
gchemist's Avatar
I just can't resist!! I've made mistakes with parts too.
Old 01-12-2011, 02:32 AM   #11
Gordonr1973
Home Built '87
I should have read the instructions in the Haynes manual to begin with...
Gordon
