Old 12-11-2010, 10:07 PM   #1
silverstreak
Wheel bearing preload / spindle nut torque?
Does anyone know the recommended front wheel bearing preload for a 72 C10 (2WD) in other words, the torque for the spindle nut?
In the past, I've snugged it down while rotating the wheel just until the freeplay is gone and called it good.
Thanks.
silverstreak is offline   Reply With Quote
Old 12-12-2010, 12:25 AM   #2
slikside
slikside's Avatar
Re: Wheel bearing preload / spindle nut torque?
I believe you have been doing it correctly, at least that's what I remember from high school autoshop! But seriously I think that's right. I mean, it's a castle nut isn't it? If so, a given torque setting would not necessarily allow you to put a cotter key in there to lock the castle nut in place.
Also, how has your past practice worked for you? If you're not burning out bearings and/or having a wheel come off periodically, I'd say you're do'in alright!
slikside is offline   Reply With Quote
Old 12-12-2010, 12:40 AM   #3
Alex Hayley
I tighten the nut until the hub begins to drag noticeably and then back the nut off until the cotter pin can be inserted. The bearing has been preloaded properly and the hub should now spin freely but with no end play.
Alex Hayley is offline   Reply With Quote
Old 12-12-2010, 08:39 AM   #4
Zeke
Active Member
This is from the 69 Chassis Manual;
1. Jack up front...
2. Tighten adjusting nut to 15 lb.ft while rotating hub in both directions.
3. Back off nut one flat (1/6 turn) and insert new cotter pin. If nut and spindle hole do not line up, back off slightly (1/6 turn) to align cotter pin. This adjustment provides for .001" to .008" bearing end clearance.
4. Spin hub to make sure it turns freely.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 12-12-2010, 05:33 PM   #5
silverstreak
Thanks Zeke, and everyone else. When I'm working on someone else's stuff I like to follow the book a little closer.
Old 03-22-2017, 03:37 PM   #6
C1ph3r
Unhappy Re: Wheel bearing preload / spindle nut torque?
Reviving this very old thread. What's the danger of over torquing when setting the bearing? Doing a disk brake conversion. I just did mine and realized my torque wrench was set to 25 ft lbs. I backed it off to line up the cotter pin. I reset it to 15 but I'm afraid I may have damaged something.
1970 C-10 LWB Build Thread
C1ph3r is offline   Reply With Quote
Old 03-22-2017, 06:48 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
No need to torque the nut. If you overtighten the nut, You can put stress on the bearing causing drag, which will cause heat, which will destroy a bearing, which can destroy a spindle.
In the 30+ years I've worked on cars and trucks I've never used a torque wrench on a spindle nut with roller bearings. No need to.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-22-2017, 09:05 PM   #8
C1ph3r
Gary
Great thanks. So what about my current situation? Do I need to pull my rotors and bearings and go get new bearings?
Old 03-22-2017, 09:11 PM   #9
saxart
saxart's Avatar
You're good. Don't fret it. 25lbs is nothing. No damage done.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 03-22-2017, 10:06 PM   #10
C1ph3r
Thanks. I'll move forward
Old 04-27-2017, 12:31 AM   #11
Meangreen1
Active Member
Yep just doing this tonight. By the way, they are the same nut 41-87 if someone wanted to know.
Meangreen1 is offline   Reply With Quote
