Old 03-06-2003, 09:33 PM   #1
ocbaud
Garage Queen Material
Talking get truck back tonight!
went into the shop last week and is just not done. i was talking to my dad on the phone and he said that he got it all running good, but didnt get a chance to replace the flywheel
i would think that having my truck over a week he would have time to do atleast that.
oh well, just something i will have to do
i just cant wait to get the truck back later tonight!
ocbaud is offline   Reply With Quote
Old 03-06-2003, 09:56 PM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
So what did they all do to it?
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-06-2003, 10:09 PM   #3
79BIG10
79BIG10's Avatar
I was talking with Heather awhile bacl on a trick that I thought about on changing a flexplate. With the tranny loose from the crossmember mount and driveshaft dropped you then undo your tranny cooler lines, and unbolt the torque converter. Then take some at least Grade 8 bolts the same size and thread as the bolts in there but these 4 bolts will be much longer (like 8"). Then take the bolts out of the sides and replace with the new ones making sure to make them tight but still plenty of bolt length left (reason for long bolts). Now undo the rest of the bolts on the housing and of course with a jack supporting the weight of the tranny slide the tranny back on the cross member (tail of tranny) and the bolts will help keep straight and keep front supported somewhat. Remeber the tranny front will be heavy and you don't want to break the bolts or bell housing so try and support tranny with a jack as much as possbile. Now you can freely get to the flywheel bolts with no trouble at all. I would only slide the tranny back enough to get a socket wrench in. Also make sure to use new bolts (same size and length) and retorque to proper specs. Then just slide tranny back onto the bell housing (aren't you glad you used the long bolts to align it properly ) and refasten everything and recheck the tranny fluid level once warm.
Old 03-06-2003, 10:11 PM   #4
ocbaud
didnt have time to ask my dad on the phone, he should be home soon with it and i'll talk to him then and then post about it after i drive it some(a lot)
