Old 12-12-2010, 01:13 AM   #1
68lwb292
Ex-Minitrucker
68lwb292's Avatar
Granny 4 PTO ?
Anyone using a PTO on the granny four speed to run anything like an air compressor or something besides a hydraulic pump?
68 C10 LWB 292 4spd
68 C10 LWB 250 3spd
68lwb292 is offline   Reply With Quote
Old 12-12-2010, 11:52 AM   #2
68lwb292
Ex-Minitrucker
68lwb292's Avatar
Re: PTO on a SM420 trans ?
Nobody?
68 C10 LWB 292 4spd
68 C10 LWB 250 3spd
Old 12-12-2010, 12:12 PM   #3
72shortbed12
I don't know much about it but I would try looking on some of the rockcrawling sites like pirate4x4. Those guys have figured out lots of mods for their rigs.
1972 K10 4wd Swb 350, 4 speed, 205 t-case Sold
1971 Cheyenne 2wd Lwb 350 4 speed Sold
1972 K5 blazer 4WD auto A/C
72shortbed12 is offline   Reply With Quote
Old 12-12-2010, 01:53 PM   #4
Shaky
Six in a row makes it go...
Shaky's Avatar
These guys might know something. They mess around with these...
http://www.novak-adapt.com/
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 12-13-2010, 10:36 AM   #5
68lwb292
Ex-Minitrucker
68lwb292's Avatar
thanks for the info guys
68 C10 LWB 292 4spd
68 C10 LWB 250 3spd
Old 12-13-2010, 12:25 PM   #6
martindc1
My 67 has a PTO output coming off the transfer case. I also know of a guy who bought a 66 K10 that the former owner used to run a grain auger, this off the transfer case as well. Though not a sm420, there is a Chevy WWII GI 4x4 with pto coming off the transmission to run the front winch. The output looks similar to the sm420.
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 12-13-2010, 01:17 PM   #7
fixit-p
fixit-p's Avatar
I've installed PTO's for anything from hydraulic to vacuum pumps, is there a specific question you have? You can find most PTO applications at phtruck.com, they don't show the SM420 (old) but here is a pic of an old application book I have, do you know the rotation of the compressor? the PTO will spin clockwise so the compressor would have to have a counterclockwise rotation (looking at the input shaft) or you can use a geared adapter to change the rotation of the PTO.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 12-13-2010, 01:18 PM   #8
Allensracing
Allensracing's Avatar
does the 420 pto turn fast enough to run a compressor? I thought they were a low RPM
Allensracing is offline   Reply With Quote
Old 12-13-2010, 02:18 PM   #9
fixit-p
fixit-p's Avatar
Thats going to depend on the compressor being used (specs are needed and all components should be sized accordingly) The fastest PTO on application page CHV-1 is the 442XXBJX-*5 it is rated @140 lb ft torque and spins at 102% of engine speed.
Old 12-13-2010, 05:14 PM   #10
68lwb292
Ex-Minitrucker
68lwb292's Avatar
I don't really have any specific questions about it just running ideas through my head and thought i would see if anyone is doing anything with them. I used to work on firetrucks and we used the PTO to run hydraulic generators anywhere from 8K to 30k.
68 C10 LWB 292 4spd
68 C10 LWB 250 3spd
