Old 12-12-2010, 03:21 PM   #1
MAC67
" SHOW ME"
MAC67's Avatar
01 tahoe "Service 4wd" light turning on.
Hey Guys . Ive been looking around on this problem and its pretty hard to narrow it down , Seems like everyone has differnt symptoms. Its a blizzard outside and a sunday afternoon so im just trying to get ideas.
Wifes truck , she just bought it with 134,000 on it. Runs down the road fine , lights ont he switch all work good. Went to go get grocerys thismorning and i hit the 4 hi " first time ive tried it since we bought it" it went right into 4 high just fine , i made it 2 miles down the road and the service 4wd light came on .
It would not let me shift back into 2hi until i shut the truck off . So i pull off to the side of the road , turn the key off , back on and boom she shifts fine back and fourth 2 hi to 4 hi but when i get to going down the road in 4 hi it will come back on and lock me into 4 hi ,
I can shut the truck off and put it back into 2hi . I know the 4wd is working , No wierd sounds aside from the normal front differential hum.
Any ideas ? could this be the switch even tho it is working ?
MAC67 is offline   Reply With Quote
Old 12-12-2010, 04:27 PM   #2
spudz
spudz's Avatar
Re: 01 tahoe "Service 4wd" light turning on.
find what the code is... its probably got a p0327 in it.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 12-12-2010, 04:28 PM   #3
spudz
spudz's Avatar
if you find out what the code is let me know and I can walk you threw it
Old 12-12-2010, 09:11 PM   #4
MAC67
" SHOW ME"
MAC67's Avatar
are you sure it would be code p0327 ? Thats a low voltage code from a knock sensor . Dont see how that can kick out a service 4wd code.
Old 12-12-2010, 10:03 PM   #5
spudz
spudz's Avatar
crap sorry got em mixed up.. I meant C0327 either way.. no way to be sure unless you have the codes pulled.. Its either going to be switch in dash, a reprogram, transfer case failure, wireing or transfer case encoder motor. Probably the encoder motor.
Old 12-13-2010, 12:25 PM   #6
MAC67
" SHOW ME"
MAC67's Avatar
Hey Spudz, i got the code thismorning . i put it in 4 high and drove around the block until it threw the service light on then took it to the shop to pull the code.
It threw a C0305 = Front propshaft speed sensor fault.
any clues ? common thing ? im guessing they are calling the driveshaft the propshaft but i could be wrong
Old 12-13-2010, 01:28 PM   #7
MAC67
" SHOW ME"
MAC67's Avatar
cant find anything for a "propshaft speed sensor" at any of the part stores.
Called the dealership and they cant either , he did however locate a screw in speed sensor on the transfercase , couldnt tell me if it was it or not. gm part number 12376520
Delco part number 213-347
Would this be the right one ?
Old 12-13-2010, 01:52 PM   #8
MAC67
" SHOW ME"
MAC67's Avatar
looks like the "21" on the left side right above the front shaft output
Old 12-13-2010, 10:08 PM   #9
spudz
spudz's Avatar
NOT COMMON AT ALL!! First make sure the wires arent chaffed anywere. Above the front driveshaft is common for this.
ohm out the front driveshaft speed sensor. should be 1300-2700ohms
if out of range replace sensor.. If its within spec. Get back with me and I will walk you through the rest of the diagnosis. Its number 7 in this pic.
Old 12-13-2010, 10:31 PM   #10
MAC67
" SHOW ME"
MAC67's Avatar
AWSOME , great diagram . Thanks , ill let you know the results when i get it inthe garage tomorow.
Old 12-14-2010, 12:44 PM   #11
MAC67
" SHOW ME"
MAC67's Avatar
I knew what the problem was within 3 seconds of sliding the creeper under the truck. the transmission has been replaced with a new one before i we got the truck . Apparently they didnt think to hook up that front speed sensor because the plug was just hanging there. I had a new delco sensor there that i had bought for 25 bucks , i went ahead and put it in because the old one was packed full of mud and ice . no sence in doing it twice for 26 bucks.
Thank you for all the help , it is GREATLY appreciated.
Old 12-14-2010, 12:56 PM   #12
spudz
spudz's Avatar
GLAD you fixed it!
